The releases alh1_2_23 and medm3_1_2_1 have R3.14 Makefiles and use
definitions from files in
the extensions/configure directory. You probably need to correct the
X11 and MOTIF definitions
in the extensions/configure/os/CONFIG_SITE.linux-x86.linux-x86 file on
the machine giving error
messages.
The older medm releases medm3_0_3Beta2 and medm3_0_3 have R3.13 type
Makefiles and use the
X11 and MOTIF definitions from the extensions/config directory.
Janet
Umashankar Panda wrote:
Dear Sirs,
I am new to tech-talk.
I have installed Red Hat Enterprise Linux 4 in two machines. In one machine
I am able to make the alarm handler alh1_2_23 and medm3_1_2_1 where as
in the other one I receive the following errors where as the
installation in both the machines are identical.
I have checked that openmotif runtime and developement are installed
in both the machine. However medm3_0_3Beta2 and medm3_0_3 are not
giving any error and running fine.
Alam Handler Error:
make[1]: *** No rule to make target `/local2/X11R6/lib/libXmu.a',
needed by `alh'. Stop.
make[1]: Leaving directory `/epics/extensions/src/alh1_2_23/O.linux-x86'
make: *** [install.linux-x86] Error 2
Medm Error:
ake[2]: *** No rule to make target `/local2/X11R6/lib/libXm.a', needed
by `medm'. Stop.
make[2]: Leaving directory `/epics/extensions/src/medm3_1_2_1/medm/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/epics/extensions/src/medm3_1_2_1/medm'
make: *** [medm.install] Error 2
Please help !!!
With regards
- Alarm Handler Umashankar Panda
Re: PV name changes and epics extensions Don Dohan
RE: PV name changes and epics extensions Rock, Judith E.
<2007>
ASYN & ioclog/CMLOG Heinrich du Toit
<2007>
