1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: MEDM compile - update :)
To: TechTalk EPICS <[email protected]>
Date: Tue, 18 Sep 2007 08:44:34 +0200
Recently libmotif-dev has been replaced with lesstif2-dev
(under ubuntu anyways)
therefore...
in the file medm/xc/Matrix.c there is a line (44 about):
/* Internal Motif functions not defined in header files */
void _XmDrawShadow();
Well under ubuntu we used to have libmotif-dev package for which this
was needed.
This has been replaced with lesstif2-dev
Now the line is no longer needed.
Infact it gives a compile error if it is there
Further:
in medm/xc/WheelSwitch.c:
line 232:
Widget _XmGetTabGroup();
Change this to:
/*Widget _XmGetTabGroup();*/
#define _XmGetTabGroup XmGetTabGroup
As XmGetTabGroup is defined now!
I'm still getting these warnings inside xc folder compile:
gcc -ansi -pedantic    -D_POSIX_C_SOURCE=199506L   -O3  -Wall   -D_X86_
-Dlinux -fPIC -D_REENTRANT  -DUNIX -D_BSD_SOURCE -I. -I..
-I/usr/X11R6/include -I/usr/X11R6/include/X11
-I../../../../include/os/Linux -I../../../../include
-I/epics/base/include/os/Linux -I/epics/base/include
-c   ../WheelSwitch.c
../WheelSwitch.c: In function âInitializeâ:
../WheelSwitch.c:687: warning: passing argument 1 of â_XmGetFocusPolicyâ
from incompatible pointer type
../WheelSwitch.c: In function âbtn1DownProcâ:
../WheelSwitch.c:2831: warning: passing argument 1 of
â_XmDispatchGadgetInputâ from incompatible pointer type
../WheelSwitch.c: In function âenterWindowProcâ:
../WheelSwitch.c:3040: warning: passing argument 1 of
â_XmGetFocusPolicyâ from incompatible pointer type
../WheelSwitch.c: In function âleaveWindowProcâ:
../WheelSwitch.c:3066: warning: passing argument 1 of
But medm compiles and seems to work :)
Prev: RE: host watchdog and PLC Bryce Karnaghan
Next: CMLOG error :( Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: Deadlock on epicsEvent Jeff Hill
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
