On Sep 18, 2007, at 9:59 AM, Jeff Hill wrote:
Hi Ben,
You might try commenting out iocInit in the startup script, and
then after
the IOC boots up type "sp iocInit". When it fails type "tt <task
id>" to get
the stack trace. If that doesn't help you might also build for
debugging and
attach the Tornado debugger to the IOC.
This is running on linux so Benjamin needs only to run the IOC under
gdb.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: Asyn/VXI-11 problems Benjamin Franksen
- Asyn/VXI-11 problems Benjamin Franksen
- RE: Asyn/VXI-11 problems Jeff Hill
Re: Beginer problem Luedeke Andreas
<2007>
2025
<2007>
2025
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
