config = EPICS base 3.13 and earlier configure = EPICS base 3.14 and beyond In this case (as in many others too) the reason for having both was for backwards compatibility. It is only fairly recently that we have published versions of the APS extensions programs that use the R3.14 build system (i.e. base/configure), so for a long time base/config was used for building most extensions programs and base/configure for IOC applications and support modules. The base/config directory will be going away in the next major release of EPICS Base, so if anybody still has any extensions code that still uses Makefile.Host I suggest you consider converting it, although I'm not seriously expecting R3.15 to be released before 2009 at the earliest. - Andrew -- When a distinguished but elderly scientist states that something is possible, he is almost certainly right. When he states that something is impossible, he is very probably wrong. -- Arthur C. Clarke
ANJ, 10 Nov 2011 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
