1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Asyn/VXI-11 problems
To: [email protected]
Date: Fri, 21 Sep 2007 15:36:21 +0200
On Friday 21 September 2007 12:30, Benjamin Franksen wrote:
> I have not produced a fix for this problem. I guess you (Eric) know
> better how to approach this.
Well, my current, very crude, solution is to replace all (seven)
clnt_destroy calls by
    if (pvxiPort->rpcClient) {
        clnt_destroy(pvxiPort->rpcClient);
        pvxiPort->rpcClient = 0;
    } else {
        if(pasynUser) asynPrint(pasynUser,ASYN_TRACE_ERROR,
            "%s internal error: RPC handle already
destroyed\n",pvxiPort->portName);
In fact I can see the above 'internal error' messages appearing when I run
our test setup.
There is yet another problem: the error checking after calls to clnt_call si
wrong. The code is
    if(stat!=RPC_SUCCESS || errno!=0) {
    	/* error handling */
which leads to pseudo errors; errno should be checked only if the return
value is abnormal. It should be just
    if(stat!=RPC_SUCCESS) {
Also, the error message should not output the numerical value of errno, but
the number converted to a string (via strerror) as is done in all other
parts of the file.
Cheers
Ben
Re: Asyn/VXI-11 problems Eric Norum
Asyn/VXI-11 problems Benjamin Franksen
Re: Asyn/VXI-11 problems Benjamin Franksen
Prev: Re: Asyn/VXI-11 problems Benjamin Franksen
Next: Re: Asyn/VXI-11 problems Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
