1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about CA and optimization
To: TechTalk EPICS <[email protected]>
Date: Thu, 27 Sep 2007 13:44:47 +0200
Ok sure.
But do you code different for number 2 than number 1?
Because in the AppDevGuide it says that everything should use CA to
access PVs and not DBaccess as described in Ch 15.
So my question is that if I run CA code inside the IOC does that somehow
bypass some networking code ect to that it directly access the PV inside
the same IOC - as if I would be working directly with DBaccess code
(ch15)
Or do I need to use DB* code?
On Thu, 2007-09-27 at 13:25 +0200, Gasper Jansa wrote:
> Hi
> Hm, maybe I misunderstand you.
> What exactly  did you mean by "running CA inside and IOC"?
> If you wrote a CA client which is not a part of the IOC application then
> of course  all communication goes via CA.
> If you have some C code inside IOC application then you can get PVs via
> database calls which are explained in AppDevGuide.
> Best Regards
> Gasper
> Heinrich du Toit wrote:
> > Hi
> > Thankyou very much for your help.
> > so why do I still need to call ca_flush_io all the time?
> > On Thu, 2007-09-27 at 12:48 +0200, Gasper Jansa wrote:
> >> Hi
> >> By default all PVs inside the same ioc connect to PV in the same IOC
> >> directly.
> >> You can however force link to go via CA stack.
> >> You can find more about links on chapter 5 in AppDevGuide.
> >> Best Regards
> >> Gasper
> >>> I just want to clarify something.
> >>> If I run CA inside an IOC and connect to a PV inside the same IOC.
> >>> Does this in effect really bypass the CA networking part and uses direct
> >>> DB access to that PV since it's inside the same program?
> >>> Or do you need to do something special to enable this optimization
> >>> thingy :)
> >>> thanx
> >>> -Heinrich
Question about CA and optimization Heinrich du Toit
Prev: Question about CA and optimization Heinrich du Toit
Next: RE: Question about CA and optimization Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
