1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Using Asyn driver or modifying devLib (or related programs) of EPICSbase for any knid of cPCI cards
To: <[email protected]>, <[email protected]>
Date: Thu, 4 Oct 2007 10:47:48 +0800
Dear Mark,
>- Using asyn driver.  You can use asyn to write your driver whether or not it uses register access, calls to a >vendor library, or some other mechanism.  In this context asyn is just a standardized interface between EPICS >device support and your driver.  This means that once you write an asyn driver you should be able to use the >asyn device support for standard records (ai, ao, bi, bo, etc.), and you don't need to write your own device >support.
This is my problem I think. How to link one asyn driver for any card? Or one driver for one card? Is there any example I can refer? Another question, Should we have to install all drivers before startup EPICS at every boot (or EPICS init function does that) (the linux version is later then 2.6)?
Jenny
RE: Using Asyn driver or modifying devLib (or related programs) of EPICSbase for any knid of cPCI cards Mark Rivers
Prev: RE: channelWatcher Zelazny, Michael S.
Next: RE: Using Asyn driver or modifying devLib (or related programs) of EPICSbase for any knid of cPCI cards Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Using Asyn driver or modifying devLib (or related programs) of EPICSbase for any knid of cPCI cards Emmanuel Mayssat
