1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Strict Monotonic Breaktable checks
To: Eric Berryman <[email protected]>
Cc: [email protected]
Date: Thu, 04 Oct 2007 09:51:30 -0500
Eric Berryman wrote:
In the Strict Monotonic Breaktable checks patch, how would a person go about making sure the variable dbBptNotMonotonic has been set to a non-zero value in st.cmd.
On vxWorks using the target shell you can say
dbBptNotMonotonic=1
in your startup script. For the other architectures that use the IOC Shell, use the syntax
var dbBptNotMonotonic 1
Note that for the latter case your src/misc/base.dbd file must have
variable(dbBptNotMonotonic,int)
in it; I might have left that addition out of the patch.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right.  When he states that something
is impossible, he is very probably wrong.  -- Arthur C. Clarke
Strict Monotonic Breaktable checks Eric Berryman
Prev: Strict Monotonic Breaktable checks Eric Berryman
Next: Re: Strict Monotonic Breaktable checks Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
