1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: longout record reading?
To: "Heinrich du Toit" <[email protected]>, "TechTalk EPICS" <[email protected]>
Date: Fri, 5 Oct 2007 08:12:07 -0500
If an output value can change due to reasons other than the output record itself then I think you need to use an input record to provide a readback of the actual value.
From: [email protected] on behalf of Heinrich du Toit
Sent: Fri 10/5/2007 7:06 AM
To: TechTalk EPICS
Subject: longout record reading?
Hallo
Ok I'm writing an asyn driver.
There is a certain option that is connected to a PV via a asynInt32
interface.
Both reading and writing of the option is allowed.
Now I can have a longout record to write to this option which is fine.
The problem is that sometimes the option changes because of something
else.
How can I force the longout record to read again?
Or is the only solution to have another longin record that will read the
value and then respond to I/O Intr from the driver?
Or can I somehow just use longout?
-Heinrich
longout record reading? Heinrich du Toit
Prev: longout record reading? Heinrich du Toit
Next: RE: asyn Array interrupts Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: PV aliases Lecorche Eric
