1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV aliases
To: Lecorche Eric <[email protected]>
Cc: [email protected]
Date: Mon, 08 Oct 2007 10:01:14 -0400
I may have been the one who initiated the discussion a few years ago. I encountered a situation which I believed was best addressed using server-side aliases. I created a patch to EPICS core (which could be loaded into a VxWorks system as a separate module), which implemented server-side aliases.
	The other option, of course, is client-side.
E.g. aliases could be managed within a name server.
At facilities which use databases to map "system
names" to PVs, such a system could be used for aliases
as well. Perhaps one of these solutions works for
you?
	If you'd like to try the server-side solution,
I can try to dig up the module. IIRC, it supported a command
(the kind that would go in st.cmd) which defined an alias
to an existing PV, a command to print out alias information,
and the support to add that alias to all the infrastructure
for name lookup inside an IOC.
HTH -- Larry
P.S. As near as I could tell, there was not universal
enthusiasm for server-side aliases at that time. Maybe
at next week's EPICS collaboration meeting the discussion
could begin anew?
Lecorche Eric wrote:
We are currently wondering about the ability of having PV aliases to help to keep naming coherence as seen from operators even though developments have been done by different people with different views, software internals, concepts or architecture etc ...
I looked within the tech-talk that some years ago, there were some discussions concerning this point. What is the current status now ? Is it possible to specify aliases to existing PVs ?
If so, how can this be achieved ? If not, are there some workarounds ?
Eric Lécorché
Re: PV aliases Heinrich du Toit
PV aliases Lecorche Eric
Prev: Re: PV aliases Ned Arnold
Next: Re: PV aliases Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
