1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Frame rate performance (was: firewire video on RTEMS-4.6.x-MVME5500)
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Wed, 10 Oct 2007 15:13:27 -0500
Emmanuel,
On Oct 10, 2007, at 1:42 PM, Emmanuel Mayssat wrote:
Hello all,
I tried frame grabber, etc. recently decided to move to an AXIS video
server. The asyn/epics driver is in development. We are reading the
mjpeg video stream (using the GPL code from axmjpeg). The throughput of
the video stream on the network can be throttled on the server side. We
use interrupt to trigger frame processing.
We completed performance testing. We can achieve the 30 frames per
second benchmark. I was shocked with the achieved performance. This
solution rocks! I gave myself a pat on the back just for thinking of it!
Load on cpu < 5%, load on local area network... negligible.
What takes time is the processing of each frame (background subtraction,
ROI, intensity monitor, etc.), so this part needs to be optimized. This
is actively being developed/reviewed.
We had a similar situation at the APS when we were upgrading our analog based frame grabber system. The amount of time to perform simple operations was adding up, and we wanted the system to perform all of the analysis operations in real time. I started using vector processing on the image data and saw substantial speed improvements. For instance, the background subtraction on an 8-bit grayscale vga size image took ~4ms using a simple for-next loop. The vector based subtraction completes in under 1 ms. I presented a poster on this at PAC over the summer and can email you a copy of the paper if you want.
Steve
Emmanuel
Here at the CLS we're using linux-based soft IOCs to
communicate with Flea and Flea2 cameras.
We're having difficulty in achieving video frame rates
greater than about 10 Hz at 640x480 resolution. I'm
interested to know how you are getting such fine performance
(aside from using RTEMS :-)
RE: firewire video on RTEMS-4.6.x-MVME5500 Mark Rivers
Frame rate performance (was: firewire video on RTEMS-4.6.x-MVME5500) Emmanuel Mayssat
Prev: EPICS Meeting this Saturday Kay-Uwe Kasemir
Next: RE: firewire video on RTEMS-4.6.x-MVME5500 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Frame rate performance D. Peter Siddons
