1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ASYN - calling read after interrupt - fix :)
To: [email protected]
Date: Thu, 11 Oct 2007 11:05:14 +0200
On Thursday 11 October 2007 09:05, Heinrich du Toit wrote:
> I think that missing data is not really a problem with records and
> thereforce device support for records.
> If all data is required it is most probably not a record but probably
> something like streamdevice or some custom record that can implement
> something else in the interrupt callback to make sure all data is
> processed.
> So I would lean towards a solution that put priority on the newest data
> out there.
> I can't really think of a record that would mind missing data?
> The only thing I think of where this is important is for Octet with a
> communications interface - in which case StreamDevice is most likely
> used and not record device support.
I agree with Mark and Eric. It may not be a problem in /most/ situations if
interrupt are lost. However, there may be cases where this is a problem. I
can imagine a card wants to acknowlege completion of a long runnign
operation by issuing an interrupt. If multiple channels per card are
involved, and each one gets its own completion interrupt, we'll have a
problem indeed. Always remember Murphy's law ;-)
BTW, if solution 2 gets implemented, I'd make sure the interrupt queue size
can be configured by the user.
Cheers
Ben
Re: ASYN - calling read after interrupt - fix :) Eric Norum
RE: ASYN - calling read after interrupt - fix :) Mark Rivers
RE: ASYN - calling read after interrupt - fix :) Heinrich du Toit
Prev: Re: Use of waveform records Touchard Dominique
Next: JavaIOC Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: ASYN - calling read after interrupt - fix :) Heinrich du Toit
Next: Re: ASYN - calling read after interrupt - fix :) Eric Norum
