1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: vxWorks network problem on MVME2700
To: "TechTalk EPICS" <[email protected]>
Date: Fri, 12 Oct 2007 15:41:09 -0500
Folks,
We have been getting network lockups on our MVME2700 boards.  This is
running vxWorks 5.4.2, EPICS 3.14.8.2, and Andrew Johnson's latest BSP
asd9-nodns.
When it happens it appears that the network is still receiving packets,
but not sending any, as seen by 2 successive ifShow commands:
ioc13ida> ifShow("dc")
dc (unit number 0):
     Flags: (0x8063) UP BROADCAST MULTICAST ARP RUNNING
     Type: ETHERNET_CSMACD
     Internet address: 164.54.160.75
     Broadcast address: 164.54.160.255
     Netmask 0xffff0000 Subnetmask 0xffffff00
     Ethernet address is 08:00:3e:2f:39:46
     Metric is 0
     Maximum Transfer Unit size is 1500
     0 octets received
     0 octets sent
     83065850 packets received
     122169709 packets sent
     83065850 unicast packets received
     122118974 unicast packets sent
     0 non-unicast packets received
     50735 non-unicast packets sent
     0 input discards
     0 input unknown protocols
     1407 input errors
     2834 output errors
     0 collisions; 0 dropped
ioc13ida>
dc (unit number 0):
     Metric is 0
     0 octets received
     0 octets sent
     83065862 packets received
     83065862 unicast packets received
     0 input discards
     1419 input errors
     2858 output errors
The above shows that the number of packets received is increasing, but
the number of packets sent is not.  It also shows that the number of
input and output errors is increasing.
mbufShow shows no free buffers of size 128 and above.
ioc13ida> mbufShow
type        number
FREE    :    150
DATA    :    581
HEADER  :     69
SOCKET  :      0
PCB     :      0
RTABLE  :      0
HTABLE  :      0
ATABLE  :      0
SONAME  :      0
ZOMBIE  :      0
SOOPTS  :      0
FTABLE  :      0
RIGHTS  :      0
IFADDR  :      0
CONTROL :      0
OOBDATA :      0
IPMOPTS :      0
IPMADDR :      0
IFMADDR :      0
MRTABLE :      0
TOTAL   :    800
number of mbufs: 800
number of times failed to find space: 22579
number of times waited for space: 0
number of times drained protocols for space: 22526
__________________
CLUSTER POOL TABLE
________________________________________________________________________
_______
size     clusters  free      usage
64       125       50        68411923
128      400       0         115759801
256      50        0         45096817
512      25        0         11828199
1024     25        0         8333
2048     25        0         1558940
netStackSysPoolShow shows no problems:
ioc13ida> netStackSysPoolShow
type        number
FREE    :    732
DATA    :      0
HEADER  :      0
SOCKET  :     95
PCB     :    116
RTABLE  :     75
HTABLE  :      0
ATABLE  :      0
SONAME  :      0
ZOMBIE  :      0
SOOPTS  :      0
FTABLE  :      0
RIGHTS  :      0
IFADDR  :      4
CONTROL :      0
OOBDATA :      0
IPMOPTS :      0
IPMADDR :      2
IFMADDR :      0
MRTABLE :      0
TOTAL   :    1024
number of mbufs: 1024
number of times failed to find space: 0
number of times drained protocols for space: 0
__________________
CLUSTER POOL TABLE
_______
64       256       206       65
128      256       154       63893
256      256       211       4103
512      256       161       63886
value = 80 = 0x50 = 'P'
Finally a command Andrew added to show the Ethernet driver pool shows no
free clusters:
ioc13ida> endPoolShow
Device name needed, e.g. "ei" or "dc"
value = -1 = 0xffffffff = ipAddrToAsciiEnginePrivate type_info node +
0xfe2f46af
ioc13ida> endPoolShow("dc")
type        number
FREE    :    432
DATA    :     80
HEADER  :      0
SOCKET  :      0
PCB     :      0
RTABLE  :      0
HTABLE  :      0
ATABLE  :      0
SONAME  :      0
ZOMBIE  :      0
SOOPTS  :      0
FTABLE  :      0
RIGHTS  :      0
IFADDR  :      0
CONTROL :      0
OOBDATA :      0
IPMOPTS :      0
IPMADDR :      0
IFMADDR :      0
MRTABLE :      0
TOTAL   :    512
number of mbufs: 512
__________________
CLUSTER POOL TABLE
_______
1520     208       0         205183548
ioc13ida>
Another command, netQueueShow shows that there have been 249 dropped
transmissions:
ioc13ida> netQueueShow
    IP Rx queue: len =    0, max =   50, drops =    0
   ARP Rx queue: len =    0, max =   50, drops =    0
   dc0 Tx queue: len =   50, max =   50, drops =  249
value = 0 = 0x0
ioc13ida>
Has anyone else been seeing such problems?  This is happening on at
least 3 IOCs with a frequency of about once per week per IOC.  Too rare
to do easy debugging, but too frequent to live with.  There does not
seem to be any correlation with something unusual happening on the IOC.
Re: vxWorks network problem on MVME2700 Maren Purves
Re: vxWorks network problem on MVME2700 Martin L. Smith
RE: ASYN - calling read after interrupt - fix :) Mark Rivers
Prev: RE: ASYN - calling read after interrupt - fix :) Mark Rivers
Next: Re: vxWorks network problem on MVME2700 Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
