Hi Emmanuel
That works indeed!
When EPICS_CAS_BEACON_ADDR_LIST is set to a proper value (the broadcast address)
before the ioc is started, the ioc does not crash the gateway any more.
Jeff, can you please have a look at the CAS? It should not be that easy to crash
a server with unexpected or malformatted requests. A server should never blindly
trust anything coming over the network.
Best regards,
Dirk
Emmanuel Mayssat wrote:
The first thing I would try is to set EPICS_CAS_BEACON_ADDR_LIST...
There was just a thread about this last week ;-)
http://www.aps.anl.gov/epics/tech-talk/2007/msg01150.php
If you use ports in EPICS_CA_ADDR_LIST (client search request), you will
need to set EPICS_CAS_BEACON_ADDR_LIST (server beacon) manually.
I think the problem you are experimenting is that the beacons are sent
to the same port where search requests only are expected.
EPICS_CAS_BEACON_ADDR_LIST default to EPICS_CA_ADDR_LIST if not set.
Check the server configuration (EPICS_CAS_* envvars) in the channel
access reference manual for more info.
Let us know if it worked!
Emmanuel
On Fri, 2007-10-12 at 14:19 +0200, Dirk Zimoch wrote:
Hi Jeff and others,
I see strange crashes of the CA gateway which probably originate in the CAS code.
If I use an explicit port in EPICS_CA_ADDR_LIST like this
EPICS_CA_ADDR_LIST="gateway:5066"
and then start a softioc running a record with an INP link to a record behind
the gateway (running on that port), the gateway starts printing errors and
refuses to handle any more requests. It has to be restarted.
The gateway prints:
CAS: CAS Request: ? on pc3853.psi.ch:38210: cmd=13 cid=0 typ=11 cnt=5064 psz=0
avail=81818260
Oct 12 14:01:36 !!! Errlog message received (message is above)
bad request code=13 in DG
filename="../../../../src/cas/generic/st/casDGIntfOS.cc" line number=498
protocol from client was invalid unexpected problem with UDP input from
"pc3853.psi.ch:38210"
avail=81818260
However, a simple caget works without problems, at least before the softioc
crashes the gateway.
I tried 3.14.8 and 3.14.9 on the ioc side. The gateway runs with some pre-3.13.9
CVS snapshot. But I also tried it with the 3.14.9 libraries.
BTW: I could not recompile the gateway with 3.14.9, because the function
epicsNTOH16 does not exist any more. I had to trick the 3.14.9 libraries into
the gateway's library search path.
Please, don't remove API functions when changing Channel Access!
Any idea?
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST Dirk Zimoch
- Re: softioc crashes CAS (gateway) when using port number in EPICS_CA_ADDR_LIST Emmanuel Mayssat
Re: fedora core 7 medm (was >> Re: MEDM compile - update :) Heinrich du Toit
Re: vxWorks network problem on MVME2700 Martin L. Smith
<2007>
2025
fedora core 7 medm (was >> Re: MEDM compile - update :) Mauro Giacchini
<2007>
2025
