1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Installing EDM on OS X 10.4.10
To: [email protected]
Date: Tue, 16 Oct 2007 12:16:02 -0700
Here is the output for doing, I have included the EPICS library in my DYLD_LIBRARY_PATH environmental variable.
Bertrand
$ sh -x setup.sh
+ echo '*'
+ '[' xdarwin-ppc = x ']'
+ echo '* Your LD_LIBRARY_PATH must be set and contain'
+ echo '* the path to your EPICS base'\''s'
* the path to your EPICS base's
+ echo '* lib/HOST_ARCH resp. lib/EPICS_HOST_ARCH directory'
+ echo '* so that we can use the CA, Com, ... libraries!'
+ echo '* It might also need to include the Motif libraries.'
+ echo '*'
++ cd ..
++ pwd
+ export EDMBASE=/usr/local/epics/extensions/src/edm
+ EDMBASE=/usr/local/epics/extensions/src/edm
+ echo Setting up EDM base directory: /usr/local/epics/extensions/src/ edm
Setting up EDM base directory: /usr/local/epics/extensions/src/edm
+ echo ''
+ ODIR=darwin-ppc
+ export EDMFILES=/usr/local/epics/extensions/src/edm/setup
+ EDMFILES=/usr/local/epics/extensions/src/edm/setup
+ export EDMOBJECTS=/usr/local/epics/extensions/src/edm/setup
+ EDMOBJECTS=/usr/local/epics/extensions/src/edm/setup
+ export EDMPVOBJECTS=/usr/local/epics/extensions/src/edm/setup
+ EDMPVOBJECTS=/usr/local/epics/extensions/src/edm/setup
+ LD_LIBRARY_PATH=/usr/local/epics/extensions/src/edm/baselib/ O.darwin-ppc:::/usr/local/epics/base-3.14.8.2/lib/darwin-ppc/
+ LD_LIBRARY_PATH=/usr/local/epics/extensions/src/edm/imagelib/ O.darwin-ppc:/usr/local/epics/extensions/src/edm/baselib/O.darwin- ppc:::/usr/local/epics/base-3.14.8.2/lib/darwin-ppc/
+ LD_LIBRARY_PATH=/usr/local/epics/extensions/src/edm/lib/O.darwin- ppc:/usr/local/epics/extensions/src/edm/imagelib/O.darwin-ppc:/usr/ local/epics/extensions/src/edm/baselib/O.darwin-ppc:::/usr/local/ epics/base-3.14.8.2/lib/darwin-ppc/
+ LD_LIBRARY_PATH=/usr/local/epics/extensions/src/edm/pvlib/O.darwin- ppc:/usr/local/epics/extensions/src/edm/lib/O.darwin-ppc:/usr/local/ epics/extensions/src/edm/imagelib/O.darwin-ppc:/usr/local/epics/ extensions/src/edm/baselib/O.darwin-ppc:::/usr/local/epics/ base-3.14.8.2/lib/darwin-ppc/
+ LD_LIBRARY_PATH=/usr/local/epics/extensions/src/edm/util/O.darwin- ppc:/usr/local/epics/extensions/src/edm/pvlib/O.darwin-ppc:/usr/local/ epics/extensions/src/edm/lib/O.darwin-ppc:/usr/local/epics/extensions/ src/edm/imagelib/O.darwin-ppc:/usr/local/epics/extensions/src/edm/ baselib/O.darwin-ppc:::/usr/local/epics/base-3.14.8.2/lib/darwin-ppc/
+ LD_LIBRARY_PATH=/usr/local/epics/extensions/src/edm/choiceButton/ O.darwin-ppc:/usr/local/epics/extensions/src/edm/util/O.darwin-ppc:/ usr/local/epics/extensions/src/edm/pvlib/O.darwin-ppc:/usr/local/ epics/extensions/src/edm/lib/O.darwin-ppc:/usr/local/epics/extensions/ src/edm/imagelib/O.darwin-ppc:/usr/local/epics/extensions/src/edm/ baselib/O.darwin-ppc:::/usr/local/epics/base-3.14.8.2/lib/darwin-ppc/
+ export LD_LIBRARY_PATH
+ export EDM=/usr/local/epics/extensions/src/edm/edmMain/O.darwin-ppc/ edm
+ EDM=/usr/local/epics/extensions/src/edm/edmMain/O.darwin-ppc/edm
+ '[' -f /usr/local/epics/extensions/src/edm/setup/edmPvObjects ']'
+ /usr/local/epics/extensions/src/edm/edmMain/O.darwin-ppc/edm - addpv /usr/local/epics/extensions/src/edm/pvlib/O.darwin-ppc/ libEpics.dylib
setup.sh: line 68: 4154 Bus error $EDM -addpv $EDMBASE/ pvlib/O.$ODIR/libEpics.dylib
+ '[' -f /usr/local/epics/extensions/src/edm/setup/edmObjects ']'
+ /usr/local/epics/extensions/src/edm/edmMain/O.darwin-ppc/edm -add / usr/local/epics/extensions/src/edm/baselib/O.darwin-ppc/libEdmBase.dylib
setup.sh: line 80: 4156 Bus error $EDM -add $EDMBASE/ baselib/O.$ODIR/libEdmBase.dylib
+ /usr/local/epics/extensions/src/edm/edmMain/O.darwin-ppc/edm -add / usr/local/epics/extensions/src/edm/imagelib/O.darwin-ppc/lib605432d2- f29d-11d2-973b-00104b8742df.dylib
setup.sh: line 80: 4158 Bus error $EDM -add $EDMBASE/ imagelib/O.$ODIR/lib605432d2-f29d-11d2-973b-00104b8742df.dylib
+ /usr/local/epics/extensions/src/edm/edmMain/O.darwin-ppc/edm -add / usr/local/epics/extensions/src/edm/choiceButton/O.darwin-ppc/ lib7e1b4e6f-239d-4650-95e6-a040d41ba633.dylib
setup.sh: line 80: 4160 Bus error $EDM -add $EDMBASE/ choiceButton/O.$ODIR/lib7e1b4e6f-239d-4650-95e6-a040d41ba633.dylib
+ /usr/local/epics/extensions/src/edm/edmMain/O.darwin-ppc/edm -add / usr/local/epics/extensions/src/edm/pvFactory/O.darwin-ppc/libPV.dylib
setup.sh: line 80: 4162 Bus error $EDM -add $EDMBASE/ pvFactory/O.$ODIR/libPV.dylib
Installing EDM on OS X 10.4.10 Bertrand H.J. Biritz
Re: Installing EDM on OS X 10.4.10 Eric Norum
Prev: RE: asyn Mark Rivers
Next: Display array of number in edm Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Installing EDM on OS X 10.4.10 Eric Norum
Next: asyn Szalata, Zenon M.
