1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Installing EDM on OS X 10.4.10
To: "Bertrand H.J. Biritz" <[email protected]>, <[email protected]>
Date: Tue, 16 Oct 2007 15:19:33 -0500
Type "bt" at the gdb prompt to get a stack trace and see what function
you are in when the access fault occurs.
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Bertrand
> H.J. Biritz
> Sent: Tuesday, October 16, 2007 2:59 PM
> To: [email protected]
> Subject: Re: Installing EDM on OS X 10.4.10
> Here is the output for gdb - I set up the EDM environmental
> variables
> to be the following:
> EDMBASE=/usr/local/epics/extensions/src/edm
> EDMFILES=/usr/local/epics/extensions/src/edm/edmMain/
> EDMHELPFILES=/usr/local/epics/extensions/src/edm/helpFiles/
> EDMOBJECTS=/usr/local/epics/extensions/src/edm/setup/
> EDMPVOBJECTS=/usr/local/epics/extensions/src/edm/setup/
> $ gdb edm
> GNU gdb 6.3.50-20050815 (Apple version gdb-573) (Fri Oct 20 15:54:33
> GMT 2006)
> Copyright 2004 Free Software Foundation, Inc.
> GDB is free software, covered by the GNU General Public License, and
> you are
> welcome to change it and/or distribute copies of it under certain
> conditions.
> Type "show copying" to see the conditions.
> There is absolutely no warranty for GDB.  Type "show warranty" for
> details.
> This GDB was configured as "powerpc-apple-darwin"...Reading symbols
> for shared libraries ............... done
> (gdb) run
> Starting program: /usr/local/epics/extensions/bin/darwin-ppc/edm
> Reading symbols for shared libraries ...++..+.++++...++++ done
> Program received signal EXC_BAD_ACCESS, Could not access memory.
> Reason: KERN_PROTECTION_FAILURE at address: 0x00000008
> 0x0021c7dc in epicsMutex::lock (this=0x1e6ecd0) at ../../../src/
> libCom/osi/epicsMutex.cpp:118
> 118             epicsMutexOsdLock(pmutexNode->id);
> Sorry to say, but I am out of my element here :)
> Bertrand
Re: Installing EDM on OS X 10.4.10 Bertrand H.J. Biritz
Prev: Re: Installing EDM on OS X 10.4.10 Bertrand H.J. Biritz
Next: Re: Installing EDM on OS X 10.4.10 Bertrand H.J. Biritz
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
