1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Initial Value
To: "Szalata, Zenon M." <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Fri, 19 Oct 2007 20:21:53 -0500
I am not familiar with the devGpib device support that you are using.  I was making a general point that EPICS output records typically do a read during iocInit to come up with the current state of the device.  I assume it is possible to do this with devGpib but I don't know how.  Eric Norum is probably the person to ask.
Sent: Fri 10/19/2007 6:38 PM
To: Mark Rivers; EPICS tech-talk
I don't understand.  You seem to be implying that the mbbo record should come up in a state which corresponds to the state of the instrument.  That is not what happens in my case.  This is my record:
record( mbbo,"$(P)$(R)WFunc"){
  field( DESC, "set function")
  field( DTYP, "ag33220")
  field( OUT,  "#L$(L) A$(A) @4")
Am I missing some field in this?  The gpibCmd is:
 {&DSET_MBBO,GPIBEFASTO,IB_Q_HIGH,0,0,0,32,0,0,0,fcmds,&func,0}
Where:
static char* funcList[]={"SIN","SQU","TRI","RAMP","NOISE","DC","USER",0};
static unsigned long funcVal[]={0,1,2,3,4,5,6,7};
static struct devGpibNames func={7,funcList,funcVal,2};
static char *(fcmds[])={"APPL:SIN","APPL:SQU","APPL:TRI","APPL:RAMP",
                        "APPL:NOISE","APPL:DC","APPL:USER",NULL};
Thanks for helping,
Zen
-----Original Message-----
Sent: Friday, October 19, 2007 3:27 PM
To: Szalata, Zenon M.; EPICS tech-talk
Yes, the device support for the mbbo record should do an initial read of the device to get the value when the IOC boots.
You can see an example in the generic asyn device support for the mbbo record in asyn/devEpics/devAsynInt32.c
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Szalata, Zenon M.
> Sent: Friday, October 19, 2007 5:24 PM
> To: EPICS tech-talk
> Subject: Initial Value
> An Agilent 33220A Wave Form Generator is attached to ICS8065
> Ethernet-GPIB controller.  I am designing a soft IOC using EPICS
> 3.14.9 and asyn 4-8.  I have setup mbbo type record to control the
> instrument function, which can have one of 7 values.  In edm I have a
> choice button connected to this record.  I can chose the function by
> clicking on one of the choices.  When the instrument is in a function
> which corresponds to any but the first choice and the IOC is
> restarted, the record comes up with some initial values consistent
> with the first choice.  Hence, the instrument and the IOC disagree on
> the function.
> Is there a simple way to initialize the mbbo record when the IOC is
> starting up so that it reflects the function selected in the
> instrument?  Thanks, Zen
RE: Initial Value Mark Rivers
Initial Value Szalata, Zenon M.
RE: Initial Value Szalata, Zenon M.
Prev: RE: Initial Value Szalata, Zenon M.
Next: RE: Initial Value Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
