(Sorry for the previous post, keyboard error)
This is strange, because you are getting the following message (which is
a known "warning" we need to fix)
> 2007/10/25 09:08:50.062 asynManager::asynConnectCallback, port L0
error calling
> asynCommon->connect L0 addr 0 vxiConnect request but already connected
So it says port LO is already connected.
But then you get this:
> 2007/10/25 09:08:50.083 AG:RFreq: asynError in write: L0 port is not
connected
Which says the port is not connected.
> -----Original Message-----
> From: Szalata, Zenon M. [mailto:[email protected]]
> Sent: Thursday, October 25, 2007 11:17 AM
> To: Mark Rivers; Dirk Zimoch
> Cc: EPICS tech-talk
> Subject: RE: Stream device
> No, this did not fix the problem. Here is what I get first
> with 1, then with 255 in the third argument...
> #!../../bin/linux-x86/atest
> < envPaths
> epicsEnvSet(ARCH,"linux-x86")
> epicsEnvSet(IOC,"iocagwfg")
> epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest")
> epicsEnvSet(ASYN,"/afs/slac/g/esa/ilc/epics/modules/asyn/4-9")
> epicsEnvSet(STRM,"/afs/slac/g/esa/ilc/epics/modules/streamdevice-2-3")
> epicsEnvSet(EPICS_BASE,"/afs/slac/g/esa/ilc/epics/base/R3-14-9-ilc1")
> epicsEnvSet( "STREAM_PROTOCOL_PATH","../../atestApp/Db:.")
> cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest
> ## Register all support components
> dbLoadDatabase("dbd/atest.dbd",0,0)
> atest_registerRecordDeviceDriver(pdbbase)
> vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
> asynSetTraceMask( "L0",0,1)
> dbLoadRecords("db/atest.db","P=AG:")
> cd
> /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest/iocBoot/iocagwfg
> iocInit()
> Starting iocInit
> ## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$
> ## EPICS Base built Oct 2 2007
> 2007/10/25 09:08:49.526 L0 port not connected
> port L0 error calling
> is not connected
> 2007/10/25 09:08:50.083 AG:RFreq: @init handler failed
> 2007/10/25 09:08:50.083 AG:RFreq: Record initialization failed
> 2007/10/25 09:08:50.083 AG:WFreq: asynError in write: L0 port
> is not connected
> 2007/10/25 09:08:50.084 AG:WFreq: @init handler failed
> 2007/10/25 09:08:50.084 AG:WFreq: Record initialization failed
> Bad init_rec return value PV: AG:WFreq ao: init_record
> iocInit: All initialization complete
> epics> exit
> zms@esaux1 $
> zms@esaux1 $
> zms@esaux1 $
> zms@esaux1 $ ../../bin/linux-x86/atest st.cmd
> < envPaths
> asynSetTraceMask( "L0",0,255)
> cd
> iocInit()
> Starting iocInit
> 2007/10/25 09:09:52.303 L0 port not connected
> 2007/10/25 09:09:52.845 asynManager connect queueCallback port:L0
> 2007/10/25 09:09:52.845 L0 addr 0 vxiConnect
> 2007/10/25 09:09:52.845 asynManager::asynConnectCallback,
> 2007/10/25 09:09:52.865 AG:RFreq: asynError in write: L0 port
> is not connected
> 2007/10/25 09:09:52.865 AG:RFreq: @init handler failed
> 2007/10/25 09:09:52.865 AG:RFreq: Record initialization failed
> 2007/10/25 09:09:52.865 AG:WFreq: asynError in write: L0 port
> is not connected
> 2007/10/25 09:09:52.865 AG:WFreq: @init handler failed
> 2007/10/25 09:09:52.865 AG:WFreq: Record initialization failed
> epics> 2007/10/25 09:10:02.868 AG:RFreq: asynError in write:
> L0 port is not conn
> ected
> exit
> Thanks,
> Zen
> From: Mark Rivers [mailto:[email protected]]
> Sent: Thursday, October 25, 2007 7:49 AM
> To: Dirk Zimoch; Szalata, Zenon M.
> Cc: EPICS tech-talk
> Hi Zen,
> Please try adding the asynSetTraceMask command to your st.cmd
> right after the vxi11Configure command.
> asynSetTraceMask("LO",0,1)
> That will force a connection to the controller before
> iocInit. See if it helps. If it does not help then change
> the line to:
> asynSetTraceMask("LO",0,255)
> so we can get a complete printout of what is happening.
> Mark
> > From: [email protected]
> > [mailto:[email protected]] On Behalf Of Dirk Zimoch
> > Sent: Thursday, October 25, 2007 6:46 AM
> > To: Szalata, Zenon M.
> > Cc: EPICS tech-talk
> > Subject: Re: Stream device
> > Hi Zen,
> > the @init handler runs during iocInit, to be exact during
> init_record.
> > Maybe the
> > vxi11 has not yet connected by that time (when interruptAccept is
> > still 0). I have to check that. I only tested it with
> serial and TCP
> > ports so far.
> > Unfortunately, not all asyn ports behave the same.
> > I have not time this week any more. I hope I can help you
> by the end
> > of next week.
> > Dirk
> > Szalata, Zenon M. wrote:
> > > I am learning to use stream device to implement a soft IOC
> > to control an Agilent 33220A waveform generator, which is
> attached to
> > an ICS 8065 Ethernet-GPIB controller. I have a very simple
> program at
> > this point. It consists of two
> > records: ai and ao and a very simple protocol file. I am unable to
> > use the @init{} command/handler. Without the @init{} commented out
> > the program works as it should. But when I uncomment either of the
> > two @init{} statements an error results. Here is the output:
> > > #!../../bin/linux-x86/atest < envPaths
> > > cd
> > > iocInit()
> > > Starting iocInit
> > > ## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$ ##
> EPICS Base
> > > built Oct 2 2007
> > > 2007/10/24 18:21:44.742 L0 port not connected
> > > 2007/10/24 18:21:45.307 AG:RFreq: asynError in write: L0
> > > 2007/10/24 18:21:45.308 AG:RFreq: @init handler failed
> > > 2007/10/24 18:21:45.308 AG:RFreq: Record initialization failed
> > > 2007/10/24 18:21:45.308 AG:WFreq: asynError in write: L0
> > > 2007/10/24 18:21:45.308 AG:WFreq: @init handler failed
> > > 2007/10/24 18:21:45.308 AG:WFreq: Record initialization
> failed Bad
> > > epics> exit
> > > Here is my atest.db:
> > > record( ai,"$(P)RFreq"){
> > > field( DESC, "read frequency")
> > > field( DTYP, "stream")
> > > field( SCAN, "10 second")
> > > field( PREC, "2")
> > > field( EGU, "Hz")
> > > field( INP, "@atest.proto rFreq L0 8") } record(
> ao,"$(P)WFreq"){
> > > field( DESC, "write frequency")
> > > field( SCAN, "Passive")
> > > field( PREC, "2")
> > > field( EGU, "Hz")
> > > field( OUT, "@atest.proto wFreq L0 8") }
> > > And atest.proto, shown here with both @init statements
> > commented out:
> > > # file: atest.proto
> > > Terminator=LF;
> > > #@init{ out " ";}
> > > rFreq{
> > > out "FREQ?"; in "%f";
> > > wFreq{
> > > out "FREQ %f";
> > > # @init{ rFreq;}
> > > Also here is atestApp/src/Makefile
> > > TOP=../..
> > > include $(TOP)/configure/CONFIG
> > > # ADD MACRO DEFINITIONS AFTER THIS LINE
> > > # build an ioc application
> > > PROD_IOC = atest
> > > DBD += atest.dbd
> > > # atest.dbd will be made up from these files:
> > > atest_DBD += base.dbd
> > > atest_DBD += atestSup.dbd
> > > atest_DBD += stream.dbd
> > > atest_DBD += asyn.dbd
> > > atest_DBD += drvVxi11.dbd
> > > # <name>_registerRecordDeviceDriver.cpp will be created
> > from <name>.dbd
> > > atest_SRCS += atest_registerRecordDeviceDriver.cpp
> > > atest_SRCS_DEFAULT += atestMain.cpp
> > > atest_SRCS_vxWorks += -nil-
> > > #The following adds support from base/src/vxWorks
> atest_OBJS_vxWorks
> > > += $(EPICS_BASE_BIN)/vxComLibrary
> > > #add a definition for each support application used by this
> > application
> > > atest_LIBS += asyn
> > > atest_LIBS += stream
> > > #atest_LIBS += genSub
> > > #atest_LIBS += calc
> > > atest_LIBS += $(EPICS_BASE_IOC_LIBS)
> > > include $(TOP)/configure/RULES
> > > # ADD RULES AFTER THIS LINE
> > > And contents of my atestSup.dbd:
> > > registrar( drvAsynIPPortRegisterCommands)
> > > When the @init statements are commented out, this is what I get:
> > > < envPaths
> > > cd
> > > iocInit()
> > > Starting iocInit
> EPICS Base
> > > built Oct 2 2007
> > > epics> dbl
> > > AG:RFreq
> > > AG:WFreq
> > > epics>
> > > And I can examine the value read in a very simple edm screen.
> > > Sorry for such a lengthy note. Thanks for helping, Zen
> > Dr. Dirk Zimoch
> > Paul Scherrer Institut, WBGB/006
> > 5232 Villigen PSI, Switzerland
> > Phone +41 56 310 5182
- RE: Stream device Szalata, Zenon M.
RE: Stream device Mark Rivers
Re: Automated logbook Matthias Clausen
<2007>
2025
<2007>
2025
