1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stream Raw converter and un/signed integrer
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Wed, 31 Oct 2007 11:26:06 +0100
Hi Emmanuel,
It should be sufficient to pass the value through a calc record that does "A&65535".
I will probably add a flag to do unsigned conversion.
Dirk
Emmanuel Mayssat wrote:
Hello all,
I am using stream and a 16 bit word to convert to an unsigned integer (0
to 64xxx). The unsigned integer is coded on 2 characters.
So I use the raw converter and particularly %2.2r
But with that converter then the integer is signed (as mentioned in the
doc). So I can read values between 0 to 32767 and -32768 to -1.
Is there a way to use unsigned integer with the raw converter or do I
have to write my own converter?
Looking at the RawConverter.cc code, I am afraid that I will have to
write my own...
Emmanuel
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
Re: Stream Raw converter and un/signed integrer Emmanuel Mayssat
Prev: Re: Stream Raw converter and un/signed integrer Emmanuel Mayssat
Next: Re: Stream Raw converter and un/signed integrer Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Stream Raw converter and un/signed integrer Dirk Zimoch
Next: Re: Stream Raw converter and un/signed integrer Emmanuel Mayssat
