1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: VMIC 2534 3.14 support?
To: "Laznovsky, Michael" <[email protected]>
Cc: [email protected]
Date: Wed, 31 Oct 2007 17:04:08 -0400 (EDT)
On Wed, 31 Oct 2007, Laznovsky, Michael wrote:
> Hi- does anyone out there have EPICS 3.14 support for the VMIC 2534
> module?  The EPICS website shows only a 3.13 version.
I have the VMIC 2536 bi/bo module which should be very similar (also on
www.fel.duke.edu/epics/ ).  I haven't looked at the 2534 manual, but I
suspect it should be a trivial port. You can also take a look at the 1182
(bi) and 2120 (bo) support on the same page.
> Found 3.14 support for VMIC 3122/4132 here:
> http://www.fel.duke.edu/epics/downloads/ (but haven't tried them yet).
They are for 3.14, but only with VxWorks. I am using the same device code
with both 3.13 and 3.14 so I'm not using the OSI layer at this point.
Let me know if you have any questions.
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
Is there any chance that I can change SCAN parameter dynamically? Zhichu Chen
Re: Is there any chance that I can change SCAN parameter dynamically? Ned Arnold
Re: Is there any chance that I can change SCAN parameter dynamically? Maren Purves
VMIC 2534 3.14 support? Laznovsky, Michael
Prev: Re: Asyn Driver with PXA255 (gumstix) and a non-standard baud rate Emmanuel Mayssat
Next: Documentation on pv crawler, etc. Eric Berryman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: VMIC 2534 3.14 support? Dale L. Brewe
Next: Re: Is there any chance that I can change SCAN parameter dynamically? Luedeke Andreas
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
