1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Tornado 2.2.2 bug
To: EPICS <[email protected]>
Date: Mon, 05 Nov 2007 14:41:35 -0600
FYI,
For anyone upgrading to Tornado 2.2.2 (VxWorks 5.5.2);  be aware that there
is a problem with target shell redirection.
Here is how I described it to Wind River Systems (WRS) in the TSR;
If the loader (ld) is invoked from the startup script using the
redirected input format (e.g., ld < test.o) rather than the file
format (e.g., ld 0,0,"test.o"), then no further redirected input
from the startup script will work.
WRS tells me that since there is a workaround (i.e., use ld 0,0,"filename"), this will not
get fixed until the next cumulative patch release (Tornado 2.2.3?).
Ron
Re: Tornado 2.2.2 bug Andrew Johnson
Prev: RE: Stream device Szalata, Zenon M.
Next: Re: Tornado 2.2.2 bug Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Need an equivalent cdCommands for RTEMS Eric Norum
