1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: question about iocConsole
To: "Allison, Stephanie" <[email protected]>
Date: Tue, 06 Nov 2007 08:43:53 -0800
While at the SNS we used procServ, developed by Dave Thompson.
procServ works really well.
After reading Ralph's posting, I am convinced we should pursue Conserv
as well.
Ernest
SLAC/LCLS
On Thu, 2007-11-01 at 11:36 -0700, Allison, Stephanie wrote:
> Hi Marco,
> I see this failure when the soft ioc failed to start.  There are other system-related reasons.
> Currently, the LCLS group at SLAC is changing to no longer start soft IOCs using the SLAC version of iocConsole and instead will use something called procServ - Ernest can give details.  Apparently, the soft IOC can freeze while somebody is paging up and down inside of screen - I've not reproduced it and debugged it though.   I also see that Ralph Lange uses something called conServer which looks interesting:
> http://epics.aps.anl.gov/epics/wiki/index.php/How_to_Set_Up_Console_Access_and_Logging_for_VME_and_Soft_IOCs
> Sorry I cannot be more help,
> Stephanie Allison
> > -----Original Message-----
> > From: [email protected]
> > [mailto:[email protected]] On Behalf Of marco_hair
> > Sent: Thursday, November 01, 2007 5:29 AM
> > To: tech-talk
> > Subject: question about iocConsole
> > hi,all:
> > I am trying iocConsole which was downloaded from
> > http://www.slac.stanford.edu/comp/unix/package/epics/extension
> > s/iocConsole/. while I met some problems.
> > If I ran the command" iocConsole ioc1"(ioc1 is defined in
> > screenioc file), I got following messages:
> > iocScreen: iocScreenStart.pl
> > /home/geyang/epicsApp2/iocBoot/iocbbb/epicsApp2.sh sioc ioc2 0
> > command failed: -1 at
> > /usr/local/epics/extensions/bin/linux-x86/iocScreen.pl line 78.
> > line 78 in iocScreen.pl is like this:
> > die "command failed: $?" unless $status ==0;
> > After I modified iocScreen.pl to change iocScreenStart's path as this:
> > $iocScreenStart=
> > "/usr/local/epics/extensions/bin/linux-x86/iocScreenStart.pl";
> > iocConsole can go down and got following messages:
> > iocScreen:
> > cd .;umask 000;/usr/bin/screen -d -m -S ioc2 -t ioc2
> > siocStart.pl
> > /home/geyang/epicsApp2/iocBoot/iocbbb/epicsApp2.sh st.cmd ioc2 0
> > screen -list ioc2: No Sockets found in /var/run/screen/S-root.
> > Timeout waiting for Multiuser session
> > command failed: 65280 at
> > Connection to 10.10.18.55 closed.
> > Can anybody gives me some suggestions? thanks a lot in advance.
> > Best wishes
> > Geyang 2007/11/1
> > ________________________________
> >  LOGO<http://mimg.163.com/hd/163/163footer/163footer_50.jpg>
> > æçåæåçåïåååèèäåé <http://popme.163.com/link/003515_0929_938.html>
> > åæååèçåèèåçåèå <http://popme163.com/link/003515_0929_938.html>
question about iocConsole marco_hair
RE: question about iocConsole Allison, Stephanie
Prev: Re: EPICS IOC startup scripts... Ralph Lange
Next: RE: Qt edm code Szalata, Zenon M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: question about iocConsole Ralph Lange
Next: webca compile on win32 鲍春雷
