Hi
I added a patch to the StreamDevice web page. It's not exactly what I sent to
Zenon but does the same thing. I also updated the CVS snapshot.
Dirk
Szalata, Zenon M. wrote:
Hi Dirk,
My test application now works after the new file you provided was installed. Thanks a million, I am happy now. I will now add all the @init calls to my full size application and hopefully all will work just as well. Thanks again,
Zen
-----Original Message-----
Sent: Wednesday, November 07, 2007 4:50 AM
To: Szalata, Zenon M.
Cc: Mark Rivers; EPICS tech-talk
Subject: Re: Stream device
Hello Zenon,
please try the attached version of AsynDriverInterface.cc with StreamDevice version 2.3.
I changed the location of the asynCommon->connect call. For me, that helped.
Dirk
Hi Mark, Dirk,
I built my test application (btest) against SLAC/LCLS EPICS R3.14.8.2, asyn 4.7, and streamdevice 2.2. Still get the following even with asynSetTraceMask( "L0",8,0):
#!../../bin/linux-x86/atest
< envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"iocbtest")
epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/btest")
epicsEnvSet(EPICS_SITE_TOP,"/nfs/slac/g/lcls/build/epics")
epicsEnvSet(ASYN,"/nfs/slac/g/lcls/build/epics/modules/asyn/asyn-R4-7-
1-lcls2")
epicsEnvSet(STRM,"/nfs/slac/g/lcls/build/epics/modules/streamdevice/st
reamdevice
-R2-2-lcls2")
epicsEnvSet(EPICS_BASE,"/nfs/slac/g/lcls/build/epics/base/base-R3-14-8
-2-lcls2") epicsEnvSet( "STREAM_PROTOCOL_PATH","../../btestApp/Db:.")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/btest
dbLoadDatabase("dbd/btest.dbd",0,0)
btest_registerRecordDeviceDriver(pdbbase)
vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
#asynSetTraceMask( "L0",0,255)
dbLoadRecords("db/btest.db","P=AG:,L=0,A=8")
cd
/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/btest/iocBoot/iocbtest
iocInit()
Starting iocInit
###### ### EPICS IOC CORE built on Oct 30 2007 ### EPICS
R3.14.8.2-LCLS_2 $R3-14-8-2$ $2006/01/06 15:55:13$
2007/11/06 20:06:48.372 AG:WFreq: asynError in write: L0 port is not
connected
2007/11/06 20:06:48.372 AG:WFreq: @init handler failed
2007/11/06 20:06:48.372 AG:WFreq: Record initialization failed Bad
init_rec return value PV: AG:WFreq ao: init_record
iocInit: All initialization complete
epics> exit
zms@esaux1 $
So, it is not my installation of these three software packages. What is it? I also ran btest with the asynSetTraceMask commented out and got exactly the same errors.
Any help is greatly appreciated. Thanks, Zen
Sent: Monday, November 05, 2007 10:38 AM
To: Szalata, Zenon M.; Dirk Zimoch
Cc: EPICS tech-talk
Subject: RE: Stream device
Dirk wrote:
I tried to do some debugging with the asynTrace facility and found
that the problem
disappears as soon as I call asynSetTraceMask, even with a 0 mask!
That is because the asynSetTraceMask causes a call to
asynCommon->connect. I had suggested this earlier to Zen. However, I
see that you used an asyn "address" of 8, while I was suggesting 0.
Zen, are you sure you tried adding the asynSetTraceMask with the subaddress that your @init device is actually using?
[mailto:[email protected]] On Behalf Of Szalata, Zenon M.
Sent: Monday, November 05, 2007 12:11 PM
To: Dirk Zimoch
Cc: EPICS tech-talk
Hi Dirk,
Unfortunately this does not solve my problem. I am using epics
R3.14.9 and asyn 4-9. This is the output I get with my simple test
soft IOC:
zms@esaux1 $ ../../bin/linux-x86/atest st.cmd
#!../../bin/linux-x86/atest < envPaths
epicsEnvSet(IOC,"iocagwfg")
epicsEnvSet(TOP,"/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest"
epicsEnvSet(ASYN,"/afs/slac/g/esa/ilc/epics/modules/asyn/4-9")
epicsEnvSet(STRM,"/afs/slac/g/esa/ilc/epics/modules/streamdevice-2-3"
epicsEnvSet(EPICS_BASE,"/afs/slac/g/esa/ilc/epics/base/R3-14-9-ilc1")
epicsEnvSet( "STREAM_PROTOCOL_PATH","../../atestApp/Db:.")
cd /afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest
dbLoadDatabase("dbd/atest.dbd",0,0)
atest_registerRecordDeviceDriver(pdbbase)
dbLoadRecords("db/atest.db","P=AG:")
cd
/afs/slac.stanford.edu/g/esa/ilc/epics/iocTop/atest/iocBoot/iocagwfg
iocInit()
Starting iocInit
## EPICS R3.14.9-lcls1 $R3-14-9$ $2007/02/05 16:31:45$ ## EPICS Base
built Oct 2 2007
2007/11/05 09:51:13.140 AG:WFreq: asynError in write: L0 port is not
connected
2007/11/05 09:51:13.141 AG:WFreq: @init handler failed
2007/11/05 09:51:13.141 AG:WFreq: Record initialization failed Bad
epics> 2007/11/05 09:51:23.143 AG:RFreq: asynError in write:
L0 port is not conn
ected
exit
zms@esaux1 $
Here are my atest.db and atest.proto files:
record( ai,"$(P)RFreq"){
field( DESC, "read frequency")
field( DTYP, "stream")
field( SCAN, "10 second")
field( PREC, "2")
field( EGU, "Hz")
field( INP, "@atest.proto rFreq L0 8") } record( ao,"$(P)WFreq"){
field( DESC, "write frequency")
field( SCAN, "Passive")
field( PREC, "2")
field( EGU, "Hz")
field( OUT, "@atest.proto wFreq L0 8") }
# file: atest.proto
Terminator=LF;
rFreq{ out "FREQ?"; in "%f";}
wFreq{ out "FREQ %f"; @init{ rFreq;}}
Here is the tail end of constructed atest.dbd file:
device(waveform,INST_IO,asynFloat64ArrayWfOut,"asynFloat64ArrayOut")
device(asyn,INST_IO,asynRecordDevice,"asynRecordDevice")
driver(stream)
driver(drvAsyn)
registrar(asSub)
registrar(streamRegistrar)
registrar(asynRegister)
registrar(asynInterposeFlushRegister)
registrar(asynInterposeEosRegister)
registrar(vxi11RegisterCommands)
registrar(drvAsynIPPortRegisterCommands)
registrar(drvAsynSerialPortRegisterCommands)
variable(asCaDebug,int)
variable(dbRecordsOnceOnly,int)
variable(dbBptNotMonotonic,int)
variable(streamDebug,int)
And finally, her is atestApp/src/Makefile:
TOP=../..
include $(TOP)/configure/CONFIG
PROD_IOC = atest
DBD += atest.dbd
atest_DBD += base.dbd
atest_DBD += stream.dbd
atest_DBD += asyn.dbd
atest_DBD += drvVxi11.dbd
atest_DBD += atestSup.dbd
# <name>_registerRecordDeviceDriver.cpp will be created from
<name>.dbd atest_SRCS += atest_registerRecordDeviceDriver.cpp
atest_SRCS_DEFAULT += atestMain.cpp
atest_SRCS_vxWorks += -nil-
#The following adds support from base/src/vxWorks atest_OBJS_vxWorks
+= $(EPICS_BASE_BIN)/vxComLibrary
#add a definition for each support application used by this
application atest_LIBS += stream atest_LIBS += asyn
atest_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
Are you using earlier versions of Epics or asyn? If you are using
the same version of these two packages, am I missing something in my
Makefile or some other files?
Thanks for helping,
Zen
Sent: Monday, November 05, 2007 5:59 AM
Hello Zen,
I tested @init handlers with several devices today. I found that TCP
ports as well as serial ports work as expected. The problem only
occurs with vxi11 ports.
However, I got different error messages:
2007/11/05 13:57:32.057 gpib0,8 vxiCreateDeviceLink RPC error
: RPC: Timed out
2007/11/05 13:57:32.058 L0 vxiCreateDevLink failed for addr 8
2007/11/05 13:57:32.058 asynManager::asynConnectCallback, port L0
error calling
asynCommon->connect
2007/11/05 13:57:36.067 L0 vxi11 clientCall errno 0 clnt_stat
5 L0 vxiBusStatus RPC error : RPC: Timed out
2007/11/05 13:57:36.067 L0 asynGpib:srqPoll srqStatus error timeout
2007/11/05 13:57:40.077 L0 vxi11 clientIoCall errno 0 clnt_stat 5
2007/11/05 13:57:40.077 DZ:cmd: asynError in write: L0 RPC failed
2007/11/05 13:57:40.078 DZ:cmd: @init handler failed
2007/11/05 13:57:40.078 DZ:cmd: Record initialization failed
StreamDevice error messages start with "asynError in write:
L0 RPC failed". All above is drvVxi11 or asynManager.
that the problem disappears as soon as I call asynSetTraceMask, even
with a 0 mask!
Thus try this in your startup script:
asynSetTraceMask ("L0",8,0)
However, I still have not the slightest idea what goes wrong in the
vxi11 driver.
I Hope this helps.
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
Dr. Dirk Zimoch
- RE: Stream device Szalata, Zenon M.
- RE: Stream device Mark Rivers
- Re: Stream device Dirk Zimoch
Re: synchronizing data to an event Till Straumann
Re: problem in running application of gpib-device Emmanuel Mayssat
<2007>
2025
unique alarms for fields? Heinrich du Toit
<2007>
2025
