1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: subArray INDX field set to 0 if NORD <= 0
Cc: [email protected]
Date: Thu, 08 Nov 2007 18:01:10 -0700
I'm pretty sure that the reason I put this in is the poor way the waveform record, on which subarray was based, posts invalid status. Certainly the subarray record support does not ever set INVALID and the waveform record does it only in a part that looks unreachable to me. The readValue() returns bad status but the process routine ignores it. It seems to me that the record should go invalid if it can't obtain input.
Although I think Lewis' argument is compelling, I also think more needs to be done than just eliminating the assignment of indx to zero.
Carl
Andrew Johnson wrote:
Hi Lewis,
J. Lewis Muir wrote:
I have found that if a subArray record reads 0 elements into its array, it sets its INDX field to 0. Is this behavior intended? I would rather it not change its INDX field in this situation.
I agree that this behavior seems a little strange and I'm inclined to apply your patch (there's nothing mentioned in the Record Reference Manual about what should happen). The record's author is listed as Carl Lionberger who is still a member of this community â Carl, do you have any comments on this change?
- Andrew
Carl Lionberger 510 486 7503
Software Developer, Engineering Division
Lawrence Berkeley National Laboratory
RE: subArray INDX field set to 0 if NORD <= 0 Gillingham, IJ (Ian)
subArray INDX field set to 0 if NORD <= 0 J. Lewis Muir
Re: subArray INDX field set to 0 if NORD <= 0 Andrew Johnson
Prev: Re: subArray INDX field set to 0 if NORD <= 0 Andrew Johnson
Next: RE: subArray INDX field set to 0 if NORD <= 0 Gillingham, IJ (Ian)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
