Thanks for the fixes. Should the get_array_info() function be changed to set *no_elements to zero when psa->udf is true? Currently it is set from psa->nelm on UDF, which looks wrong to me. Should the same apply in cvt_dbaddr()? If you think there should be changes in the waveform record that make it behave more sensibly and won't break documented behavior I'd be happy to consider them. - Andrew -- When a distinguished but elderly scientist states that something is possible, he is almost certainly right. When he states that something is impossible, he is very probably wrong. -- Arthur C. Clarke
ANJ, 10 Nov 2011 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
