1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: exception
To: "EPICS Techtalk" <[email protected]>
Date: Sun, 11 Nov 2007 13:33:40 -0800
Ever so often when I exit from soft IOC I get this:
epics> exit
epicsThread: Unknown C++ exception in thread "CAC-UDP" at Sun Nov 11 2007 13:09:
48.024072000
terminate called without an active exception
Aborted (core dumped)
The IOC is built with EPICS 3.14.9, asyn 4-9, streamdevice 2-3, gensub 1-6, and calc 2-6-3.  Is this a known problem?  Is there a fix for that?  I suppose that is possible that I am doing something wrong in my code, although I am not using any C or C++ code of my own.  Thanks in advance,
Zen
Re: exception Heinrich du Toit
Prev: Re: CA protocol dissector Andrew Johnson
Next: Re: exception Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: subArray INDX field set to 0 if NORD <= 0 Andrew Johnson
