1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CA protocol dissector
Cc: Ron Rechenmacher <[email protected]>, [email protected]
Date: Mon, 12 Nov 2007 15:35:26 -0600
Hi Andrew,
[email protected], Fri, 09 Nov 2007 15:09:47 -0600, said:
> Was your message sent because you are currently experiencing problems  with
> CA for which you need to watch the wire traffic?
I was not actually experiencing problems with CA, but the problem in general
is how to synchronize data from CA and other sources, where there is a
significant push to see if something other than "time of day" could be used as
the basis for synchronization. I wanted to have an assurance that I knew what
information the channel archiver was collecting (or could possible be
collecting) by looking at the information it was collecting over the network.
So, I fired up my version of ethereal with the dissector I did long ago.
I was quickly able to see (confirm) that the DBR_TIME_DOUBLE information
was being sent.
With my background, with the way I think, and with my general level of
non-experience with CA, this was the most direct way for me to know for sure
what info the archiver was collecting -- and ethereal really can organize the
information clearly.
Then I thought I should finally search tech-talk for "protocol dissector"
because I, by this time, had gained familiarity with tech-talk.
--Ron
Re: CA protocol dissector Andrew Johnson
Prev: Re: exception Heinrich du Toit
Next: help Xu HuiJuan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CA protocol dissector Andrew Johnson
Next: Call for expressions of interest for ILC controls R&D and engineering Margaret Votava
