1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asynGpib:srqPoll srqStatus is 1 after ntrys 5 Why?
To: Dirk Zimoch <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Tue, 13 Nov 2007 11:01:02 -0500 (EST)
On Tue, 13 Nov 2007, Dirk Zimoch wrote:
> There is only one device on the bus. I didn't understand that the
> message means "some device does not release SRQ".
It means that your device (or some device on the bus) is asserting the
"Service Request" line (pin 10), trying to notify the controller that it
needs attention. The controller does a srqPoll to see which device on the
bus has asserted SRQ.  The device should de-assert SRQ when it is polled,
but after 5 tries at srqPoll, the SRQ is still asserted.
First, check that there is no other device on the bus which may be
asserting SRQ. Then check your cable/connectors. If it is still a problem,
it may be a badly behaving GPIB device (which unfortunately is not very
uncommon).
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
asynGpib:srqPoll srqStatus is 1 after ntrys 5 Why? Dirk Zimoch
Re: asynGpib:srqPoll srqStatus is 1 after ntrys 5 Why? Eric Norum
Re: asynGpib:srqPoll srqStatus is 1 after ntrys 5 Why? Dirk Zimoch
Prev: Re: help Dirk Zimoch
Next: Re: embedded python :) Heinrich du Toit
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: asynGpib:srqPoll srqStatus is 1 after ntrys 5 Why? Dirk Zimoch
Next: 250kV ION source control Heinrich du Toit
