1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 250kV ION source control
To: Heinrich du Toit <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 14 Nov 2007 09:16:32 -0800
On Wed, 2007-11-14 at 11:59 +0200, Heinrich du Toit wrote:
> Hi there
> We have an Multi-sample ion source of negative ions by Ceium sputtering
> for AMS application.
> So I was thinking maybe RS485 protocol.
If you were thinking about differential communication over copper wire,
this wouldn't work. If you look at the specs of anything that can be
configured as differential (ADC, DAC, serial,...), you will read that
ground potential + max differential voltage as to be within a range.
With your 250V offset, you probably don't meet that specification.
Opto-coupling may be the only solution.
E
250kV ION source control Heinrich du Toit
Prev: RE: help Jeff Hill
Next: Power Supply Record? Susanna Jacobson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 250kV ION source control Steve Lewis
Next: Latest IP Card Drivers for IOC Blade 9010 Darrell Nineham
