Just to add to the consensus. I also strongly recommend using templates
of basic record types, rather than creating a custom record. There's
very little that can't be done with the existing semantics of basic
records and links (although admittedly it can take a while to learn all
the tricks). For me, it became clear quickly that if I went the custom
record route, I would wind up with 5 or more custom records, each of
which then has to be debugged and maintained. Then, when you consider
tweaks to add functionality later on, it is easier to link in a few new
basic records than it is to try and integrate a tweak into the C support
code of a large custom record.
regards, Claude
Susanna Jacobson wrote:
Hello folks,
Here in the Controls Group at the Advanced Light Source, we are
considering writing a custom Power Supply record. If your
installation has one already, would you share it with us for reference?
I would also welcome any advice or cautions you have, based on your
experience in this area.
Thanks in advance,
Susanna
- Anyone have Epics support for ADSC 315r CCD detector? Russ Berg
- Power Supply Record? Susanna Jacobson
RE: WIENER crate Elder Matias
<2007>
Re: Power Supply Record? Geoff Savage
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
