1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: iocLogServer simple browser
To: "Matt Rippa" <[email protected]>
Cc: [email protected]
Date: Thu, 15 Nov 2007 13:16:34 -1000
Thanks!
-----Original Message-----
Sent: Thursday, November 15, 2007 1:05 PM
To: Al Honey
Cc: MacKenzie, Ronald R.; [email protected]
Subject: Re: iocLogServer simple browser
At Gemini we use a Perle CS9000 console server.
http://www.perle.com/products/CS9000-Console-Server.shtml
It has an NFS log feature which includes timestamps. We couple
this with an in-house log rotation scheme which works quite well.
This is completely independent from iocLog.
-Matt
Al Honey wrote:
> Actually the iocLog in and of itself is insufficient as it does not
> capture low level operating system panic calls. At Keck, we log the
IOC
> console output, of course that has no time tags and must be correlated
> with the iocLog to determine when events occurred, which is sometimes
> tedious.
> Several months back there was an e-mail thread on processes that allow
> good terminal server/console monitoring and logging. It could be
useful
> to review that thread.
> Cheers,
> Al
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Maren Purves
> Sent: Thursday, November 15, 2007 8:53 AM
> To: 'MacKenzie, Ronald R.'
> Hi Ron,
> we log to a new file each day, and if you want to read it you
> can use system commands like less, tail, grep, or some combination
> of the those (something along the lines of "tail -f <file>| grep
> <machine>")
> HTH,
> Maren
> Jeff Hill wrote:
>> Hi Ron,
>>> Does a simple little program exist in C to read the iocLogServer
>>> circular file as messages are written to it?  I'm just wanting to
see
>>> the circular file messages from the program on the screen (stdout).
>> I'm not aware that any program like that exists.
>> Perhaps a superior approach would be to modify the log server so that
> it
>> sends the log messages by default to stdout if the
> EPICS_IOC_LOG_FILE_NAME
>> environment variable isn't defined (or is empty). I suppose also that
> the
>> logic in the log server implementing a circular file would need to be
>> selectively disabled if the file descriptor being written to isn't a
> file
>> (we could easily test the file descriptor to see if it is a file or
> not).
>> There are probably already some UNIX command line tools that pipe
> their
>> input to a length constrained circular file? And of course the
command
> line
>> tool tee can be used to break out to multiple destinations.
RE: iocLogServer simple browser Jeff Hill
Re: iocLogServer simple browser Maren Purves
RE: iocLogServer simple browser Al Honey
Re: iocLogServer simple browser Matt Rippa
Prev: Re: iocLogServer simple browser Matt Rippa
Next: building device support on external library - help needed John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
