1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SDDS lapack compile error
To: "Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]" <[email protected]>
Cc: [email protected]
Date: Fri, 16 Nov 2007 13:17:33 -0500 (EST)
On Fri, 16 Nov 2007, Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO] wrote:
> QUESTIONS:
>      Has StripTool really been compiled sucessfully ?   Seems to work.
Yes. SDDS includes lots of stuff, but StripTool doesn't need most of it.
You got enough of SDDS compiled to make StripTool.
>      How do I add "lapack" to make the "ld" linker happy?  Is "lapack"
> needed for other extensions?
lapack is a linear algebra library. Unless you are using SDDS for
analysis, you don't need it. But the SDDS build will fail without it and
it doesn't appear to be setup to allow a partial build of SDDS (just to
get the libraries needed for StripTool, burt, etc. for example).
If you want to install lapack and blas (which SDDS also needs) on FC-6:
	yum install lapack-devel blas-devel
(If you are building on Solaris, there are some additional complications.)
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
SDDS lapack compile error Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
Prev: Re: SDDS lapack compile error Rodney R. Porter
Next: Re: SDDS lapack compile error Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: SDDS lapack compile error Janet Anderson
