1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Streams questions
To: Eric Berryman <[email protected]>, [email protected]
Date: Tue, 20 Nov 2007 15:19:12 -0600
Use a scalcout record
Mohan
[Message delivered by NotifyLink]
----------Original Message----------
Sent: Tue, November 20, 2007 3:11 PM
To: [email protected]
Subject: Streams questions
Hello!
I've run into a problem I'm guessing others have solved using the
Streams module.  I have a device that outputs reads in the format:
U1\r\n+00011-01\r\n
meaning 11e-01 , which would be the preferred format for using a
general format specifier in the protocol file.
What would be the format to successfully read in this number from the
Streams protocol file?
(Or, will I have to run as a string read through a c filter program,
sub record)
Thank you!
Eric
Prev: Streams questions Eric Berryman
Next: Re: EPICSデータサーバの件【再確認】 Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Streams questions (how to read +00011-01 as 11e-01=1.1) Dirk Zimoch
