I'm looking for some information on how you solve this problem... We need to measure currents.. from harps and slits and faraday cups. All of this gives of currents that is important. Some of the currents we measure with keithleys but it is way to expensive to buy keithleys for harps as you will need 100's of them :) We need to measure currents between nA and uA range for harps and slits. For faraday cups this sometimes goes to 100+ uA but our main problem is harps/slits. I hope that we are not the first to have this problem, is there some cost effective method to solve this problem? That can give descent results. The problem can basically be given as: How do I measure 50+ current inputs (harp = 96, 4 per slit-set) across a wide range (2nA fullscale = 50pA sensitive up to 100uA full scale) still have resonable accuracy especially between the lines and have a descent update rate and not 2 high noise levels. (I guess noise can to some extend be solved with a software filter if updates are high enough) Thanks for your support :) -Heinrich
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
