1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: current measurement - hardware
To: <[email protected]>
Date: Tue, 27 Nov 2007 17:19:56 +0100
Title: RE: current measurement - hardware
Hello Heinrich
Maybe you can check our solution: http://www.microioc.com/loco.htm
Here you can find pdf description: http://www.microioc.com/download/microIOC-PD-LOCO.pdf
We can measure currents in the range of 100pA - 10mA at voltages up to 10kV. You can also define interlock current value per each channel. Standard product consists of 16 modules for current measurements, but it is configurable to your applications. We also provide complete control system integration support.
It is based on current to voltage to frequency converter with integration functionality that filters out noise by itself. Question that arises to me is, what is the current readout rate you require?
You can contact us directly and we shall help you with this.
Joze
|¯|_|¯|_|¯|__|¯|_|¯|___|¯|_____
Joze Dedic, Ph.D.
Chief Hardware Developer
Cosylab, Teslova 30, SI-1000 Ljubljana, Slovenia
Phone: +386 1 4776 759
www.microioc.com / www.cosylab.com
Prev: SoftIOC console access under Windows? Ralph Lange
Next: Re: current measurement - hardware Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: current measurement - hardware Rolf Keitel
Next: EPICS PHP Extension David Dudley
