1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SoftIOC console access under Windows?
To: EPICS tech-talk <[email protected]>
Date: Wed, 28 Nov 2007 14:03:22 +1100
Hi Ralph,
For our standard environment of Linux based soft IOCs, we start up the IOC using the "screen" utility and access the box (and the screen session) via SSH. (You don't mention what your standard text based environment is.)
We have only a couple of Windows based IOCs at this stage, and have not yet had a need to replicate this standard "screen" approach. However, your query has prompted me to see some definite benefits. So far, we have installed Cygwin/SSH for text based maintenance but this does not include starting the IOC. (Cygwin is a UNIX environment running on top of Windows). Cygwin is capable of starting win32 apps - you should not need to recompile your IOCs for cygwin-x86 specifically in order to run them. I believe using the screen utility under Cygwin could be an option worth exploring, although I have never tested it.
Let me know if you need more detail and please advise us of your final solution.
regards,
Mark Bennett
Deputy Controls Manager
Australian Synchrotron
Ralph Lange wrote:
Hi -
does anyone have a (text based) solution to remotely access the console of a soft IOC running under Windows?
All we do now is access the Windows box using graphical tools like vnc or rdesktop - which is not really convenient and doesn't match the way the other IOCs are handled.
Ralph
Re: SoftIOC console access under Windows? Ralph Lange
Prev: RE: JCA using problem Guobao Shen (KEK)
Next: MVME6100 or 7100 Matt Rippa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: SoftIOC console access under Windows? Ralph Lange
Next: Re: SoftIOC console access under Windows? Ralph Lange
