it is I once more, the early adopter of OS X 10.5 :) After the initial help of getting base to build (thanks once more for the incredible prompt turn around) I didn't run into any problem building the Alarm Handler nor even MEDM (thought I would with the later). Now I am trying to build SDDS - latest version downloaded from their website. I run into the following error: make -C O.darwin-ppc -f ../Makefile TOP=../../../.. T_A=darwin-ppc install /usr/bin/c++ -o libgd.3.14.9.dylib -dynamiclib -flat_namespace - undefined suppress -install_name /usr/local/bin/epics/extensions/lib/ darwin-ppc/libgd.3.14.9.dylib -compatibility_version 3.14 - current_version 3.14.9 -L/usr/local/bin/epics/extensions/lib/darwin- ppc -L/opt/local/lib/ gd.o gdfx.o gd_security.o gd_gd.o gd_gd2.o gd_io.o gd_io_dp.o gd_gif_in.o gd_gif_out.o gd_io_file.o gd_io_ss.o gd_png.o gd_ss.o gd_topal.o gd_wbmp.o gdcache.o gdfontg.o gdfontl.o gdfontmb.o gdfonts.o gdfontt.o gdhelpers.o gdkanji.o gdtables.o gdxpm.o wbmp.o gdft.o gd_jpeg.o - lpng -lz -lXpm -lreadline -lm -lgcc ld: library not found for -lXpm collect2: ld returned 1 exit status make[2]: *** [libgd.3.14.9.dylib] Error 1 make[1]: *** [install.darwin-ppc] Error 2 make: *** [gd.install] Error 2 Now, when I used Mac Ports (switched from Fink to try it out) to install Xpm it get the error message: Activating xpm 3.4k_0 Error: Target org.macports.activate returned: Image error: /usr/X11/ bin/cxpm already exists and does not belong to a registered port. Unable to activate port xpm. Error: Status 1 encountered during processing. Naturally my question is how I get SDDS to build? My ultimate goal is to get the VLinac to run on my machine. It is really a great way to test if everything is working and to try out new things. Thanks once more, Bertrand
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
