1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: JCA using problem
To: "'Chu, Chungming Paul'" <[email protected]>, "'???'" <[email protected]>
Cc: [email protected]
Date: Thu, 29 Nov 2007 10:18:13 +0900
Hi Paul,
I think there may have a problem when compiling the JCA/JNI library using
MSVC2005.
With my old JCA/JNI library (v2.1.7) compiled using MSVC2003 free toolkit,
the code works fine.
With the library compiled by MSVC2005, a message windows is popped up.
which says as following: (The JCALibrary.properties is same.)
	Microsoft Visual C++ Runtime Library
	Runtime Error!
	Program: C:\java\jdk1.5.0_14\bin\java.exe
	R6034
	An application has made an attempt to load the C runtime library
incorrectly.
	Please contact the application's support team for more information.
A tracking message throws from java code is as fllowing:
	Exception in thread "main" java.lang.UnsatisfiedLinkError:
	C:\Java\epics\jca-2.1.7\O.win32-x86\jca.dll:
	A dynamic link library (DLL) initialization routine failed
	        at java.lang.ClassLoader$NativeLibrary.load(Native Method)
	        at java.lang.ClassLoader.loadLibrary0(Unknown Source)
	        at java.lang.ClassLoader.loadLibrary(Unknown Source)
	        at java.lang.Runtime.loadLibrary0(Unknown Source)
	        at java.lang.System.loadLibrary(Unknown Source)
	        at gov.aps.jca.jni.JNI$1.run(JNI.java:100)
	        at java.security.AccessController.doPrivileged(Native
Method)
	        at gov.aps.jca.jni.JNI.init(JNI.java:110)
	        at
gov.aps.jca.jni.JNIContext.initialize(JNIContext.java:109)
	        at
gov.aps.jca.jni.JNIContext._initialize(JNIContext.java:145)
	        at
gov.aps.jca.jni.ThreadSafeContext.createChannel(ThreadSafeContext.java:330)
	        at gov.aps.jca.Context.createChannel(Context.java:113)
	        at test.main(test.java:25)
For the version 2.3.1, a similar error was thrown also.
Guobao
-----Original Message-----
From: Chu, Chungming Paul [mailto:[email protected]]
Sent: 2007年11月29日 2:12 AM
To: Guobao Shen (KEK); ???
Yes, I think Guobao is right.  I tested your code on my Windows box and it
worked fine (with everything set correctly).  The output looks like this:
CLASS : gov.aps.jca.jni.ThreadSafeContext PREEMPTIVE_CALLBACK : true
ADDR_LIST : xxxxxx.sns.ornl.gov AUTO_ADDR_LIST : false CONNECTION_TIMEOUT :
30.0 BEACON_PERIOD : 15.0 REPEATER_PORT : 5065 SERVER_PORT : 5064
MAX_ARRAY_BYTES : 16384
EVENT_DISPATCHER: gov.aps.jca.event.QueuedEventDispatcher@1749757
PRIORITY : 1
gov.aps.jca.TimeoutException: pendIO timed out
Of course, for my ADDR_LIST, I don't have a channel called 'light' and got
pendIO timed out error.
I also attach my JCALibrary.properties file from my Windows box (it's set to
use JCA/JNI, same as in your example).  If you're using Linux, you need to
follow the Linux syntax.
If you need further help, could you send more detailed info about the
exception thrown and maybe screen print-out?
Paul
On Behalf Of Guobao Shen (KEK)
Sent: Tuesday, November 27, 2007 6:32 PM
To: '鲍春雷'; [email protected]
Hi Bao,
You need set some environment parameter properly for JCA in
JCALibrary.properties file before you start using it.
There is a tutorial under doc directory if you downloaded the source code.
Some some detail explanation can be found in that file about how to
setJCALibrary.properties .
BTW: Which OS do you use, Linux, Win/XP, ...?
Do you compile the JCA library from source code by yourself?
Guobao Shen
To: [email protected]
Subject: JCA using problem
                                       Hello,all
	I am using JCA to do some experment.But the first program can not
run.The error message is:java.lang.IllegalStateException: Context not
initialized.
	My environment:
	JDK 1.5
	JCA 2.3.1
	EPICS 3.14.8
	The program:
import gov.aps.jca.Channel;
import gov.aps.jca.Context;
import gov.aps.jca.JCALibrary;
public class test {
	public static void main(String[] args) {
		 try {
			  JCALibrary jca= JCALibrary.getInstance();
		      Context ctxt=
jca.createContext(JCALibrary.JNI_THREAD_SAFE);
		      ctxt.printInfo();
              Channel ch= ctxt.createChannel("light");
			  ctxt.pendIO(5.0);
		      ch.printInfo();
		     ch.destroy();
		      ctxt.destroy();
		    } catch(Exception ex) {
		      System.err.println(ex);
BaoChunlei
Control Group,IHEP
RE: JCA using problem, JCA/JNI for Windows Chu, Chungming Paul
JCA using problem 鲍春雷
RE: JCA using problem Guobao Shen (KEK)
Prev: Re: Problem installing SDDS on OS X 10.5.1 Bertrand H.J. Biritz
Next: RE: JCA using problem, JCA/JNI for Windows Chu, Chungming Paul
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: JCA using problem Guobao Shen (KEK)
