Hi all, Hi Emma, We don't have this particular temperature controller in our collection of serial devices at SLS, but we do have the Lakeshore models 331 and 340. Unless the PSI firewalls are blocking access, the CVS repository of the software should be visible here: www.sls.psi.ch/cgi-bin/cvsweb.cgi/G/DRV/lakeshore/ We also have support for Oxford Instrument's cryojet with liquid nitrogen auto fill controller (same URL, substitute "cryojet" for "lakeshore"). They both have the same structure: a collection of simple stream-device EPICS records for sending commands and status requests to the device, glued together with an snl program. There's a bit of documentation on setting up the cryojet at: www.sls.psi.ch/controls/help/howto/cryojet.html but unfortunately nothing for the Lakeshore controllers. Getting the Cryogenic Control Systems device to work with the Lakeshore code might simply be a case of a new stream-device protocol file. For the helium depth indicator, you might consider simply connecting its analogue output to an ADC channel, rather than using its serial port. Regards, David
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
