1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Stream protocol configuration
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Wed, 05 Dec 2007 12:15:27 -0800
Dirk,
I am having issues with the protocol configuration.
For most of them I have found work-arounds, but let's see what other
people do/did/suggest.
1/ MaxInput
I noticed that the maxInput (and probable most other directives) do not
work in the @init or other exception handler. The maxInput for a
particular protocol can be set globally, locally, but not in exception
handlers. Am I missing something?
2/ Parameter passing
I am able to refer to another protocol entry in the exception handler
Example:
writeRegister {
  @init {
     readRegister;
But I can pass parameters to the writeRegister protocol.
But how can I pass those parameters to the readRegister in the @init ?
Emmanuel
Re: Stream protocol configuration Dirk Zimoch
writing your own stream cronverter Emmanuel Mayssat
Re: writing your own stream cronverter Emmanuel Mayssat
Re: writing your own stream converter Emmanuel Mayssat
Prev: Re: Cryocon and TSI hardware support? David Maden
Next: Re: Stream protocol configuration Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: writing your own stream converter Emmanuel Mayssat
