Dear All,I can't remember that any package was missing while building EPICS base, but for the extensions (esp. the Motif-applications) you definitely need a Motif-library. I strongly suggest to install the "original" Open Motif packages (libmotif3 and libmotiv-dev) instead of the lesstif-packages. Unfortunately the Open Motif packages are *not* available in Debian 4.0 (etch - the current "stable" distribution) and have to be installed from the current "testing" distribution. The Channel Archiver brings an own set of source tar-balls of ThirdParty software-modules, that you as well should unpack, build and install to be used when building the ChannelArchiver. Other than that, you may have encountered some perl-modules missing. We install these as soon as we encounter any perl-error-message like (Can't locate XYZ.pm in @INC (@INC contains: ...). I unfortunately don't have a list of packages at hand right now, but I'll add a list of modules we additoinally install on our development and our production systems later. Additionally, some Error-Messages from the build-process or from running the EPICS-applications will sure help to identify the missing packages. Feel free, to send me these messages and I might remember/be able to look up what we did here at BESSY. Regards, Thomas -- ___________________________________________________________________________ Thomas Birke BESSY GmbH Albert-Einstein-Str. 15, D-12489 BERLIN BESSY GmbH - Mitglied der Leibniz Gemeinschaft Vorsitzender des Aufsichtsrates: Prof. Dr. Dr. h.c. mult Joachim Treusch Geschäftsführer: Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Prof. Dr. Eberhard Jaeschke Sitz Berlin, AG Charlottenburg, HRB 14635
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
