Wouldn't it be nice to specify the EPICS_CA_* values firstly through functions in the library rather than environment variables only. And then secondly on a per-connection basis. So you can have seperate setup for every PV connection. ? Is it possible to link casw into a program somehow? So that your client program can monitor the status of a specific IOC? It would be nice if the ARRAY_SIZE_LIMIT thing be done differently? Maybe removed all-together? Or be implemented in a way that it can be easily changed on the fly inside a program - The documentation aint very clear if this env-var is read while the program is running or only on startup? Then a question: Can somebody explain the relationship between. ca_flush_io ca_poll ca_pend_io ca_pend_event And which ones of these I don't have to call in a enabled pre-emptive callback environment? And lastly - with the CA library. How do I control users - password ect in case of Access Control on IOC's ? Thanks you for your answers in advance :) -Heinrich
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
