1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: mca R6-10 released
To: <[email protected]>
Cc: [email protected], [email protected]
Date: Fri, 21 Dec 2007 14:46:12 -0600
Folks,
I have released version R6-10 of the EPICS "mca" module for multichannel
analyzer systems.
These are from the release notes (available at
http://cars.uchicago.edu/software/epics/mcaReleaseNotes.html)
- mcaSrc
   - Fixed bug in MCA record. The record must force a read of the data
whenever acquisition completes (.ACQG=1 changes to    .ACQG=0). In
earlier versions it could miss this transition if acquisition was
complete by the time of the first status poll. The bug fix in R6-9
attempted to fix this, but it was inefficient and not completely
effective. The new fix is for the record to force .ACQG=1 whenever
acquisition is started, and not rely on the poll to set .ACQG to 1.
- CanberraSrc
   - Changed the code to read data from the new AIM modules (556A,
DSA2000) in uncompressed mode. This improves the performance by about a
factor of 3 over the previous code which used compressed mode for all
AIM models. These newer models are very slow to compress the data
because they lack a co-processor. The older 556 modules are still read
in compressed format, because it is faster. With this change the time to
acquire spectra quickly from the 556 and 556A is virtually identical.
Performance measurements are tabulated here:
http://cars9.uchicago.edu/software/epics/mcaCanberra.html#Performance%20
Measurements
   - Added code to use LLC sockets on vxWorks (rather than etherLib) and
Linux (rather than libnet and libpcap). Thanks to Peter Denision of DLS
for the initial version of this code. This change is needed for vxWorks
5.5, because the older etherHook functions are no longer supported. It
is also useful on Linux because the IOC application does not need to be
run as root.
- RontecSrc
   - Bug fix for Rontec driver. It was sometimes getting garbage for the
elapsed real time. (Thanks to Lewis Muir).
The main page for this module is here:
The documentation is here:
http://cars.uchicago.edu/software/epics/mcaDoc.html
Happy Holidays,
Prev: RE: Help with udev Mark Rivers
Next: gateway throttling events? Chris Timossi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
