1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: erro when writing to the GPIB device on softIOC
To: [email protected]
Date: Fri, 18 Jan 2008 05:59:24 +0100
Hello,
On Monday, January 14 2008, Emmanuel Mayssat wrote:
> On Mon, 2008-01-14 at 16:29 +0800, zhangdemin99 wrote:
> >  I am trying to communicate with the GPIB device on the softIOC with
> > GPIB bus.
> > I am sure the device and the PCI-GPIB card are connected well.
I assume your are implying softIOC == linux-x86 == linux-gpib here.
Can you talk to the device using ibtest from linux-gpib? What is the GPIB
address of the device?
> > The command array I set are:
> >  {&DSET_SO,GPIBWRITE,IB_Q_LOW,NULL,":CURRent:STEP %
> > S",50,50,NULL,0,0,NULL,NULL,NULL},
> >     {&DSET_SI,GPIBREAD,IB_Q_LOW,":CURRent:STEP?","%39[^\r
> > \n]",0,50,NULL,0,0,NULL,NULL,NULL}
The ":CURRent:STEP" commands above (quite literally reproduced from the
device's manual ;-) indicate the device talks a SCPI-like protocol.
> Before you jump into devGpib, you may want to have a look at
> streamDevice.
Exactly. With help of the marvelous StreamDevice (see
http://epics.web.psi.ch/software/streamdevice/), such a device is comfortably
EPICS-ified.
STEP 1: In a fresh and clean directory, do
makeBaseApp.pl -t example gpib
makeBaseApp.pl -t example -i -a linux-x86 -p gpib gpib
STEP 2: Append to configure/RELEASE
ASYN=/opt/epics/support/asyn
STREAMS=/opt/epics/support/streamdevice
Make sure you have asyn and StreamDevice installed and supply the correct
paths to your EPICS support directories.
STEP 3: Create a protocol file, gpibApp/Db/yourdev.proto, like this:
=== gpibApp/Db/yourdev.proto ===
Terminator = CR LF;
getCurrentStep {
        out ":CURR:STEP?";
	in "%f";
setCurrentStep {
	out ":CURR:STEP %f";
You might want to consult the SCPI command reference for your device and
implement whatever part of the protocol you may need.
STEP 4: Create a database, gpibApp/Db/yourdev.db, matching the protocol like
this:
=== gpibApp/Db/yourdev.db ===
record (ai, "$(P)currentStep")
        field (SCAN, "Passive")
        field (DTYP, "stream")
        field (INP,  "@yourdev.proto getCurrentStep $(PORT) $(ADDR)")
record (ao, "$(P)setCurrentStep")
        field (OUT,  "@yourdev.proto setCurrentStep $(PORT) $(ADDR)")
STEP 5: In order to register your database with the build system, add the line
	DB += yourdev.db
in the middle of gpibApp/Db/Makefile.
STEP 6: Have gpibApp/src/Makefile read:
=== gpibApp/src/Makefile ===
TOP=../..
include $(TOP)/configure/CONFIG
# build an ioc application
PROD_IOC = gpib
PROD_LIBS += asyn
PROD_LIBS += stream
# gpib.dbd will be created and installed
DBD += gpib.dbd
# gpib.dbd will be made up from these files:
gpib_DBD += base.dbd
gpib_DBD += asyn.dbd
gpib_DBD += drvAsynIPPort.dbd
gpib_DBD += drvAsynSerialPort.dbd
gpib_DBD += drvLinuxGpib.dbd
gpib_DBD += stream.dbd
# softIOC house-keeping
gpib_SRCS += gpib_registerRecordDeviceDriver.cpp
gpib_SRCS_DEFAULT += gpibMain.cpp
gpib_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
STEP 7: Have the IOC's st.cmd look like this:
=== iocBoot/iocgpib/st.cmd ===
#!../../bin/linux-x86/gpib
< envPaths
epicsEnvSet(STREAM_PROTOCOL_PATH, "../../gpibApp/Db")
cd ${TOP}
## 1  Register all support components
dbLoadDatabase("dbd/gpib.dbd")
gpib_registerRecordDeviceDriver(pdbbase)
## 2  Configure your asynPorts
#  2a GPIB: portname, autoConnect, boardId, timeout, 5th_arg
GpibBoardDriverConfig("L0", "1", "0", "3", "0")
#     Note: boardId is the GPIB address *of your GPIB controller board*. The
#     GPIB address of the _device_ is supplied to dbLoadRecords in step 3.
#  2b TCP/IP socket:
#drvAsynIPPortConfigure("IPPORT","192.168.0.1:6789")
#  2c Serial: "COM1", 9600 bps, 8N1, flow contr.: XON/XOFF
#drvAsynSerialPortConfigure ("SERIALPORT", "/dev/ttyS0", 0, 0, 0)
#asynSetOption ("SERIALPORT", 0, "baud", "9600")
#asynSetOption ("SERIALPORT", 0, "bits", "8")
#asynSetOption ("SERIALPORT", 0, "parity", "none")
#asynSetOption ("SERIALPORT", 0, "stop", "1")
#asynSetOption ("SERIALPORT", 0, "clocal", "Y")
#asynSetOption ("SERIALPORT", 0, "crtscts", "N")
#  2d vxi11: ...
## 3  Load record instances
# make sure you have your device's GPIB address right!
dbLoadRecords("db/yourdev.db", "P=${IOC}:,PORT=L0,ADDR=2")
cd ${TOP}/iocBoot/${IOC}
iocInit()
STEP 8: Finally run
make
cd iocBoot/iocgpib
chmod +x st.cmd
./st.cmd
to get something like
Starting iocInit
## EPICS R3.14.9-3 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Jan 17 2008
iocInit: All initialization complete
epics> dbl
iocgpib:currentStep
iocgpib:setCurrentStep
epics> dbpf iocgpib:currentStep.PROC 1
DBR_UCHAR:          1         0x1
epics> 2008/01/18 05:17:01.124 L0 addr 2 : device timed out.
2008/01/18 05:17:01.125 iocgpib:currentStep: Timeout after reading 17
bytes "-000.0007E-12ADC<0a>"
2008/01/18 05:17:01.125 iocgpib:currentStep: 4 bytes surplus input "ADC<0a>"
2008/01/18 05:17:01.125 iocgpib:currentStep: after 13 bytes: "-000.0007E-12"
epics>
The response here comes from my Keithley 6517A sitting at address 2 and
doesn't exactly match what we expect. In fact, not even our EOS terminator
setting is correct, that's why the device timeouts. With the exemplary
debugging information provided by StreamDevice at hand, it is a joy to
incrementally fix the "in" clauses in yourdev.proto to match what the device
_really_ sends. Here, the getCurrentStep protocol would need to be changed to
Terminator = LF;
getCurrentStep {
        out ":CURR:STEP?";
	in "%fADC";
You can reload the protocol in the iocsh via "streamReload", either for one or
for all records. Without rebooting the IOC. Without any recompilation.
Once the protocol works, do a dbpf/caput iocgpib:currentStep.SCAN ".1 second"
to have your IOC poll the device regularly. Or even better, have the device
send out readings on its own if possible and parse them in a protocol run
from an record with .SCAN="I/O Intr".
StreamDevice offers a broad range of so called format converters (the "%f" in
the in clause of the getCurrentStep protocol in yourdev.proto). There's even
a regular expression string converter that you can use to parse your favorite
stock quote from a web page into an EPICS variable.
> You may want to try to attach an asynRecord to the interface and
> communicate with it directly. Doing so, you will bypass devGpib.
asynRecord is a fantastic diagnostic aid (asynOctet.adl!), it has saved me a
lot of time while integrating several RS-232/USB and Ethernet devices in our
setup, yet I never got it to work on a linux-gpib port. The .ADDR of the asyn
record was set correctly and got successfully used on connect(), but in
gpibRead() in drvLinuxGpib.c getAddr() for the asynUser would yield -1.
Sorry for the lengthy post, everbody, I was hoping I could pay back to the
EPICS community a little bit.
HTH,
-Stefan
Stefan Heim, PhD Student X-ray microscopy
BESSY mbH, Albert-Einstein-StraÃe 15, D-12489 Berlin, Germany
voice: +49 30 6392 3177 fax: + 49 30 6392 4757 e-mail: [email protected]
BESSY mbH - Mitglied der Leibniz Gemeinschaft
Vorsitzender des Aufsichtsrates: Prof. Dr. Dr. h.c. mult. Joachim Treusch
GeschÃftsfÃhrer: Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Prof. Dr. Eberhard
Jaeschke
Sitz Berlin, AG Charlottenburg, HRB 14635
erro when writing to the GPIB device on softIOC zhangdemin99
Re: erro when writing to the GPIB device on softIOC Emmanuel Mayssat
Prev: Re: CA connection management problem Maren Purves
Next: RE: CA connection management problem Owens, PH (Peter)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: erro when writing to the GPIB device on softIOC Emmanuel Mayssat
Next: 2008 EPICS meeting website SQLiu
