1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: XDMCP
From: "Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]" <[email protected]>
To: <[email protected]>
Date: Wed, 20 Feb 2008 10:34:10 -0600
            I have some EPICS systems with Linux Fedora 6 computer hosts that need remote X-term operations.
Does anyone still use remote X-terminals supported by XDMCP with Fedora 6 through Fedora 8 ?  Or at least a Linux that uses the X window system X.org (http://wiki.x.org) ?
            Redhat Linux up thru Version 9 and Fedora Core 1 used the XFree86 X-Window System (http://www.xfree86.org/).  The X-Window System was switched to Xorg at about Fedora Core 2.
             XDMCP worked up through Fedora Core 1 for me.  But I have been unable to get any version of Fedora that uses Xorg instead of XFree86 to work properly.
1. Between Fedora computers using Xorg, XDMCP works and as expected.
2. With Fedora computers using Xorg, I can not get XDMCP to work with other XDMCP remotes including X-term boxes and computer systems
            Problem that I can’t get to work is the same on a X-term or any computer, other than Fedora (xorg):
            1. The XDMCP Fedora background window starts ok.
            2. The Fedora Login box is drawn on the background window.
            3. Login box does not complete (fill) and the process exits.
            4. Then this startup process repeats.
            Any documentation or information, that I can get, only tells how to setup Linux XDMCP using XFree86 files.
            If anyone has solved this problem using Xorg, I WOULD GREATLY APPRECIATE THE SOLUTION.
Billy R. Adams
Prev: Re: Having problems with training site David Dudley
Next: Multiple target os-class application build Sue Witherspoon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: TTL output with soft IOC on Linux Mark Rivers
