1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: TTL output with soft IOC on Linux
To: Jiro Fujita <[email protected]>
Cc: "; heinrichdt"@tlabs.ac.za, EPICS tech-talk <[email protected]>
Date: Fri, 22 Feb 2008 12:09:39 -0800
As I mentioned earlier have a look at comedi.org for PCI devices.
On there website you will find a list of supported hardware.
I use mostly measurement computing equipment, but many more vendors are
supported.
For example, I use the DDA0816 which has 8 AO and 48 configurable TTL
outputs. Works great but pricey if you just want to use the TTL outputs.
I also heard that there is a comedi interface for asyn.
I never used it, but you may want to have a look at it
https://sourceforge.net/projects/epicscomedi/
Good luck,
E
On Fri, 2008-02-22 at 13:40 -0600, Jiro Fujita wrote:
> Thanks, Emmanuel.
> Running EPICS on Linux is not the problem.  I have been doing that for
> a few years.
> We have a relatively large number (~ 100) of FEE cards that only takes
> on and off via TTL.  All what it does is turn on or off the FEE card.
> So, using the parallel port probably will not work.
> I guess I am looking for if anybody is controlling any devices via TTL
> using a PCI card in Linux using EPICS.  If so, I would like to know
> which TTL interface card and exactly how you are doing that.
TTL output with soft IOC on Linux Jiro Fujita
Re: TTL output with soft IOC on Linux Emmanuel Mayssat
Re: TTL output with soft IOC on Linux Jiro Fujita
Prev: Re: TTL output with soft IOC on Linux Jiro Fujita
Next: Re: TTL output with soft IOC on Linux Steve Lewis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
