I just know JCA and I think it's great. I want to give it a try so I follow the installation manual of JCA 2.1.2. And I got some problems: 1, I took a look at the download page of JCA and found that the oldest release is 2.1.3, and I can't find the ancient version the manual mentioned over Google. Finally, I choose to download the current release 2.3.1. I looked at the change page on http://jca.cosylab.com/changes-report.html and I suppose it didn't changed so much. Am I right? And is there a newer version of the installation tutorial? 2, Since I didn't download the 2.1.2 version as the manual said, I couldn't get the jca.dll mentioned there. I downloaded it from http://joimint.desy.de/download/dlls/ . Would that be OK? Or we just don't need that link library any more so it's not included in the package? 3, I do have tried to compile from source but failed at: ============================== =============================== C:\epics\java\jca-2.3.1-src\jca-2.3.1>ant Buildfile: build.xml build.core.java: [echo] Building core classes [echo] Copying ressources [echo] Done -init: build.core.jni.dirs: build.core.jni.depend: [echo] Building native header files [echo] Done build.core.jni.objs: [echo] Building native object files [applyex] C:\Program Files\Microsoft Visual Studio\VC98\bin\cl -nologo -c -GX -GR -D__STDC__=0 -Ox -W3 -MD -IC:\Program Files\Java\jdk1.6.0_04\jre/../include -IC:\Program Files\Java\jdk1.6.0_04\jre/../include/WIN32 -IC:\epics\base-3.14.8. 2/include -IC:\epics\base-3.14.8.2/include/os/WIN32 -IC:/Program Files/Microsoft Visual Studio/VC98/include -IO.win32-x86 -FoC:\epics\java\jca-2.3.1-src\jca-2.3 .1\O.win32-x86\JNI.obj C:\epics\java\jca-2.3.1-src\jca-2.3.1\src\core\gov\aps\jc a\jni\JNI.cpp BUILD FAILED C:\epics\java\jca-2.3.1-src\jca-2.3.1\build.xml:199: applyex returned: -10737415 15 Total time: 0 seconds ============================================================= and my system environment is set by: ============================================================= set HOST_ARCH=win32-x86 set EPICS_HOST_ARCH=win32-x86 set EPICS_BASE_RELEASE=C:\epics\base-3.14.8.2 set EPICS_EXTENSIONS=C:\epics\extension set JAVA_HOME=C:\Program Files\Java\jdk1.6.0_04 set PATH=%PATH%;C:\epics\java\ant\bin ============================================================= is there anything wrong or what did I forget? By the way, I hope there could be an option to choose MinGW compiler. I don't like the price of MS VC++ and it fails to compile the CVS epics base. So can any of you could tell me how this jca.dll would be compiled and I'll just write a makefile to compile it. Any inputs would be appreciated. -- Best Regards Chen ---------------------------------------------------------------- Zhi-chu Chen | Shanghai Synchrotron Radiation Facility No. 2019 | Jialuo Rd. | Jiading | Shanghai | P.R. China tel: 086 21 5955 3405 | zhichu.chen.googlepages.com | www.sinap.ac.cn ----------------------------------------------------------------
ANJ, 02 Sep 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
