Subject: Re: Minor VLinac compilation problem on OS X 10.5?
To: "Bertrand H.J. Biritz" <[email protected]>
Cc: [email protected]
Date: Wed, 27 Feb 2008 12:04:01 -0500
I don't know about the Virtual Linac, but I added the following lines to the EPICS base file, config/os/CONFIG.darwinCommon.darwinCommon
# X11 and motif paths
MOTIF_LIB = /opt/local/lib
MOTIF_INC = /opt/local/include
X11_LIB = /usr/X11/lib
I needed these lines to build other MOTIF based EPICS applications.
best regards,
tom
On Feb 23, 2008, at 1:56 PM, Bertrand H.J. Biritz wrote:
Dear Tech-Talk,
so I finally got around to installing more of EPICS on my Mac (PowerBook G4, OS X 10.5.2). I came across this error message while trying to compile the Virtual Linac:
make[2]: *** No rule to make target `../../lib/darwin-ppc/libXm. 3.dylib', needed by `build'. Stop.
I checked in MacPorts and OpenMotif provides libXm.4.dylib. When changing the following in the Makefile located in install/App
LIBLIST_Darwin := libXm.3.dylib
to
LIBLIST_Darwin := libXm.4.dylib
I still get an error message.
When commenting out the line the compilation proceeded without any errors. Running the program I didn't come across any obvious problems.
So my question is: did I do something "illegal"?
Bertrand
Minor VLinac compilation problem on OS X 10.5? Bertrand H.J. Biritz
Prev: Problems with edm-1.11.1 on Linux (and OS X) Eric Norum
Next: Problems with edm-1.11.1 on Linux (and OS X) Eric Norum
Prev: Minor VLinac compilation problem on OS X 10.5? Bertrand H.J. Biritz
Next: Re: Minor VLinac compilation problem on OS X 10.5? Eric Norum
