1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Initialize multi-element field
To: [email protected]
Cc: [email protected]
Date: Wed, 27 Feb 2008 13:39:43 -0600
Benjamin Franksen wrote:
On Friday 22 February 2008 20:08, Tim Mooney wrote:
(Note the above file must end with '\n' or "\r\n".)
is there a rationale behind this? If not, I think this should be fixed.
Similar remarks apply, BTW, to other EPICS tools. For instance, I noticed in the past that dbExpand silently ignores the last line of a dbd include file if it doesn't end in a newline. This has caused endless grief to Windows users, as editors for Windows generally don't automatically add a newline at the end.
If this hasn't already been fixed, I propose to put it on the list of things to be done before the next release of base. I'd say chances that people rely on the faulty behaviour are practically zero.
This is not a problem in base. Autosave simply needs to know that the file it's restoring from was not corrupted by an ioc crash that occurred while the file was being written. The simplest and most common artifact of such a crash is a truncated file, and autosave detects this by requiring the last few characters of the file to fit a pattern that is unlikely to occur in the middle of the file, and by always ending the files it writes in this way. Some systems use "\r\n" as an end-of-record character, and some use "\n", so both are permitted.
Autosave was not intended to process files written by humans.  If this use
becomes common enough, it will be worthwhile to code a relaxed reader that
recognizes files written by humans, and doesn't require any special end pattern.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
Re: Initialize multi-element field Benjamin Franksen
Initialize multi-element field Dehong Zhang
Re: Initialize multi-element field Tim Mooney
Prev: Re: Multiple target os-class application build Sue Witherspoon
Next: edm version 1-11-1 John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Initialize multi-element field Benjamin Franksen
Next: Re: Initialize multi-element field Benjamin Franksen
