On Feb 27, 2008, at 1:31 PM, John Sinclair wrote:
Mark,
Your old screens should be compatible.
As of 1-11-1, the file named edmPvObjects has been changed somewhat
and must be repopulated. The easiest way to accomplish this is as
follows:
mv edmPvObjects edmPvObjects-old
edm -addpv /somedir/libEpics.so
dm -addpv /somedir/libLoc.so
dm -addpv /somedir/libCalc.so
where /somdir is the location of the referenced sharable libraries.
Sorry for the lack of documentation. I failed to clearly state the
requirement to repopulate edmPvObjects.
If this does not fix your problem, let me know.
I see neither libLoc nor libCalc when I build edm-1-11-1. I see only
baselib/O.linux-x86/libEdmBase.so
Am I neglecting to build something or building something improperly?
I see a calc_pv_factory in lib/O.darwin-x86/libcfcaa62e-8199-11d3-
a77f-00104b8742df.3.14.9.dylib -- is that in place of or in addition
to libCalc.so?
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Are EDM screens forwards compatible from version 1-10 to 1-11? Mark Bennett
- Re: Are EDM screens forwards compatible from version 1-10 to 1-11? John Sinclair
Tech-talk delivery delays Andrew Johnson
Re: Initialize multi-element field Andrew Johnson
<2008>
2025
compiler options Heinrich du Toit
<2008>
2025
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
